Most power made from standard turbo??
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
aroS3
Re: Most power made from standard turbo??
Post by aroS3 » Tue Feb 17, 2004 2:20 pm
For sure you can handle 550 cc injectors with the stock ECU. If you want bigger ones you have to change to aftermarket EMS. For up to 550 cc it's proven in an S3 and Seat Leon ~ 500 hp..and as for the chipped cars the next move is the enhanced clutch for sure.
Regards,
George.
Just had a chat with my tuner about the s3 and there becoming revo dealers,so i might see what they can achieve with this first.Injectors-v.small as i suspected and will need replacing to 440 if going to 300+ bhp.These may have to be controlled by a standalone but he's not totally sure.
The compressor map shows theoretical safe power output of 230bhp although revo claim a max of 280bhp.The k04 turbo isn't the strongest unit and he recommends a ihi unit with a decent cast manifold for 330-370hp.He reckons 260-280bhp if your lucky with the revo,although this is a max figure due to the stock manifold which is a restriction.The clutches can be a bit marginal in terms of what they can take, even with a chip upgrade. It seems the options for
this car are either a Helix clutch, or a hybrid using a VR6 pressure plate.Anyone had problems with their clutch after a chip upgrade?upgrades?The engine is strong with mahle pistons and can run 1.35bar no problem.
more updates soon,regards Ryan
Ryan_s3
Post by Ryan_s3 » Tue Feb 17, 2004 6:43 pm
Which clutchs are tried and tested with big power on the s3?I am put off from getting the helix because i had one in my last car as i was making in excess of 280bhp(240 at the wheels) and it was basically all or nothing and was very harsh although effective.Who has a mtm clutch?Does it keep the stock feel?Any others?I don't think my car has had the clutch changed since new and it's done 40k so it must be nearly time for a change.Did you say you have revo fitted ben?What are your thoughts?Aro,how is it possible to swap injectors without some sort of management?regards Ryan
Image360bhp 342lb/t
bjacks
Post by bjacks » Tue Feb 17, 2004 6:53 pm
Mick has an MTM clutch for sure. Simon Elman runs a paddle clutch and a lightened flywheel so he can help on that front. VST no doubt has some kind of upgrade as well [img]images/graemlins/grin.gif[/img]
Revo was good. I got a nice curve on the rollers at AmD with 260/290. The car was running brilliantly when I sold it.
Ben
DuncS3
Post by DuncS3 » Tue Feb 17, 2004 6:53 pm
Chelsea Mick and S3mon are running the MTM clutch. I have driven S3mons car and I would say it is pretty much close to stock feel. One of these guys should be able to comment better.
Dunc [img]images/graemlins/s3addict.gif[/img]
Ryan_s3
Post by Ryan_s3 » Tue Feb 17, 2004 9:57 pm
Thanks for the comments guys.It was a helix 4 paddle clutch i had in my previous car and it was v harsh.That mtm one sounds pricey for what it is.Sounds like i need to budget for this aswell as my chip upgrade.regards Ryan
Image360bhp 342lb/t
s8n
Post by s8n » Tue Feb 17, 2004 11:17 pm
Id also like to know how you run 550cc injectors without an aftermarket ems or remap...
Audi S3
aroS3
Post by aroS3 » Wed Feb 18, 2004 6:56 am
I'm not running the 550 cc injectors, but my cousin who is also an Audi - VW tuner did several upgrades with them in S3 and Leon cars. Of course you have to reprogram the stock ECU in order to make the 550 cc work. As i explained the 550 cc are the top ones you can work with the stock ECU even if reprogrammed.
Regards
Brocki
Post by Brocki » Fri Mar 19, 2004 12:08 am
My S3 has with the original Turbo ca. 300PS ! And you can drive it every day long. The S3 is running 86TKm yet ! :twisted: And is the same fast as the first day, so I think ! :twisted:
My S3 has many modifications:
- B&B performance opimation level 2
- B&B pre-exhaust pipe
- B&B race catalysts 100 CPSI
- B&B stainless steel exhaust system 70mm starting from catalyst
- B&B aluminium air conduction
- B&B special pressure pipe incl. race Pop Off valve EVO 6
- K&N K57i
- optimized ventilation of the load air coolers
- B&B 4-pistons sports brake system 322mm at the front axle incl. steelflex
connections and B&B air plates as well as Castrol SRF- racing brake fluid
- toe broadening, 30mm front axle, 50mm rear axle
- Bilstein PSS9 thread chassis
- B&B short-shift
- boost pressure indicator
- digi Oil Temp
mfg
Brocki
AUDI S3 powered by B&B-Automobiltechnik
Porsche/AUDI RS2
Riz_RS4
Post by Riz_RS4 » Fri Mar 19, 2004 12:10 am
Very impressive spec indeed.
Das ist sehr gut ;)
Riz
Image I`m just a hardcore petrol head :)
Brocki
Post by Brocki » Mon Mar 22, 2004 1:44 am
Thank you, I think so, too !
mfg
Brocki
Porsche/AUDI RS2
Return to “S3 (Typ 8L) 1999-2003”
