Cheap valve covers on TPM!
Keaney
Post by Keaney » Sun Feb 06, 2011 8:12 pm
Well when it came to checking the tyre pressures on each wheel I found that some cheap valve caps had been used and have now corroded onto the valves! Even a pair of pliers doesnt seem to do the job and started to mis-shape the valve.
Now i'm torn between getting new sensors for the wheels with the valves or seeing if i can just get the valves replaced.
Any help or ideas would be greatly appreciated
Coxall8395
RE: Cheap valve covers on TPM!
Post by Coxall8395 » Sun Feb 06, 2011 9:10 pm
Audi do specific ones that wont fuse with metal used on the valves.
Post by Shoppinit » Mon Feb 07, 2011 8:53 am
Use a dremel to slice the old valve caps off. Grind a groove axially on the cap without going all the way through, then use a flat blade screwdriver to try and split the cap by inserting it in the groove and twisting. Careful not to go too deep when cutting.
55marcuss
Post by 55marcuss » Mon Feb 07, 2011 12:33 pm
The valves are £50 odd quid for four from audi
Its the alloy wheel cleaner that speeds up the corrosion, but using good quality plastic caps ( the ones with a seal inside ) is the way to go IMO
The new valves come with these..
For trouble free motoring just ditch the sensors and valves and get some bog standard rubber jokers!
philroach
Post by philroach » Tue Feb 08, 2011 3:31 pm
liberal use of copper grease stops the rusting , once the caps are off !
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Keaney
Post by Keaney » Wed Feb 09, 2011 12:41 am
Thanks for advice, gonna have a go at them this weekend.
Think vagcom said only one of my tpm sensors had a flat battery so tempted to leave them on for now.
Always been a fan of black plastic caps! They are less appealing to kids, functional and lightweight haha
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Post by Shoppinit » Wed Feb 09, 2011 10:07 am
Yeah, I learned the cap lesson the hard way once. Will now never put anything on but cheapo plastic ones.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 154 guests
