GEARBOX PROBLEM!!! WTF NOW...
RS6Steve
Post by RS6Steve » Fri Feb 04, 2011 9:49 am
You are not having much luck!
These things make a grown man/woman cry daily....
I HATE mine but struggle to get my head around selling it
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
marv8
Post by marv8 » Fri Feb 04, 2011 9:59 am
My TC went and yes it is a big job - there are people in the us that can change the gearbox without taking the engine out but they seem to be a little way ahead of us.
I had the box out, inspected by the warranty company, sent TC to Sussex autos who confirmed the issue. Warranty company inspected again and approved a claim. Sussex autos suggested a full box rebuild as there could be swarf in the box.
Had the box stripped to individual components and replaced everything that was not perfect ( box was under 10k miles old). Zf actually supplied some uprated parts according to the guy that's doing the work as they know what the failure rate is!
It's a kick in the balls - I know it was for me and I had a warranty ( only covered £3k though) but took the opportunity to replacetiming belt (6k old but makes sense if engine out) water pump, stat, rocker cover gaskets, crank oil seal and just had new alternator. Hoping prevention is the cure for any of the usual faults!
Good luck mate, fingers crossed it's just low fluids
jd_hants
Post by jd_hants » Fri Feb 04, 2011 11:37 am
Mine did a similar thing and turned out to be low ATF as an oil pipe to the cooler was weeping. Luckily a flush and new ATF and seems ok. Hope it's as simple as that for you. Def worth a shot.
RS6MAN
Post by RS6MAN » Fri Feb 04, 2011 9:12 pm
Hey boys, i took to my local audi specialist today and they did a full vagcom and no faults were present... My mate drove the car to the garage which is 20mins away and he didnt have any problem, the mechanic took it for a test drive and was fine, gearbox was also inspected and fine... Im getting a service done on it replacing the fluid, filters, gaskets etc...
What could have it been??!
Its weird...
Cornishmoocher
Post by Cornishmoocher » Sat Feb 05, 2011 8:08 am
Hmmmm..... would i trust Audi.... No.
They would tell you no faults present if it meant replacing a gearbox under warranty......
When they did mine, I noticed a weep from the sump. By this time i had told audi they were a bunch of useless cnuts and taken it to unit 20. Grizz found, and i saw this with my own eyes every single nut on the sump fingertight, except one..... which was not there at all..... Oh and my milltek had been put on with no clamps or bolts either......
Grizz please confirm.........
It's all Bollox.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Feb 05, 2011 9:24 am
Your doing the right thing - get the oil inspeccted and serviced. If it keeps doing the thud it should throw a code for something - solenoid, tq, gear selector - so until it does be careful.
http://www.MRCtuning.com
RS6MAN
Post by RS6MAN » Sat Feb 05, 2011 7:34 pm
Doug_S2 wrote:Your doing the right thing - get the oil inspeccted and serviced. If it keeps doing the thud it should throw a code for something - solenoid, tq, gear selector - so until it does be careful.
just got my car back from the audi specalist and its all fine; they changed the filter in the box, gasket, seals and oil...
its goes into gear more smoother and i dont have no thud anymore; they did say the oil was low...
marv8
Post by marv8 » Sat Feb 05, 2011 8:23 pm
Well mate one word for that............. Result!
RS6MAN
Post by RS6MAN » Sat Feb 05, 2011 9:17 pm
yh i no; just hope all stays as good as is now...
Digger
Post by Digger » Sat Feb 05, 2011 10:00 pm
Do you mind telling who the Audi guys were that you used? Might be of use to some others depending where they are in the country in case its a long way to travel to the usual suspects. :)
RS6MAN
Post by RS6MAN » Sun Feb 06, 2011 12:52 am
oh yh sure; guy called bobby at 4rings in colnbrook slough...
25 years audi mechanic now has his own garage with all equipment; 1 thing i was amazed to see today was the machine used to repressurize the drc... i thought only audi had that...
RichRS6
Post by RichRS6 » Sun Feb 06, 2011 12:38 pm
RS60786 wrote:oh yh sure; guy called bobby at 4rings in colnbrook slough...
That's interesting, I thought the DRC tool was dealer only too...........
Useful for those still on DRC to have an option if they need work doing on it.
03 Mugello Blue Avant, Silver Leather, Carbon Fibre, Alcantara Headlining, MFSW, Electric folding Mirrors. H&R Coilovers, Hotchkis ARB's, Res Miltek, APR R1's, ITG Filters, RNS-E, OEM Bluetooth, Digital Freeview and Headrest Monitors, Aero Wipers, Rear Aero Wiper and R/H parking Mod, Rear Fog mod, Valentine 1.
RS6MAN
Post by RS6MAN » Sun Feb 06, 2011 1:31 pm
yeh and he did quote around £1000 for full drc change; not bad compared to £1800 from audi...
Digger
Post by Digger » Sun Feb 06, 2011 4:19 pm
Yep very interesting and timely. I'm off to see Rob at Camberley on Wednesday to have my DRC checked out. Work may well need to be done so its nice to have another option if needs be. Thanks for the info.
Users browsing this forum: Steve2003rs6 and 35 guests
