Best injector cleaner for RS4
wolfgang
Post by wolfgang » Fri Jan 28, 2011 11:53 pm
I want to run a bottle of injector cleaner through the fuel tank of my RS4. I bought the car with 51K miles on it so it's a fairly high miler. It's had nothing other than Shell V-Power since I bought it but I have no idea what fuel was used for the first 51K miles.
For those of you who have used fuel additives to clean the injectors and fuel system, what are your experiences with them and what, if any, benefits did you notice? Are they all much of a muchness?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
Ice_Coffee
RE: Best injector cleaner for RS4
Post by Ice_Coffee » Sat Jan 29, 2011 12:09 am
well if audi are to be believed, then strictly no other products than
"Fuel additive for petrol engines, available under - Part No.: G 001 700.03"
ArthurPE
Post by ArthurPE » Sat Jan 29, 2011 12:24 am
I like LubroMoly
P_G
Post by P_G » Sat Jan 29, 2011 12:27 am
I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
d10uug
Post by d10uug » Sat Jan 29, 2011 1:03 am
P_G wrote:I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
Hi PG do you have a link to where this can be bought, as I have heard good things about it but cant seem to find a seller.
Cheers for the help
Dougie
madgreek
Re: RE: Best injector cleaner for RS4
Post by madgreek » Sat Jan 29, 2011 5:42 am
Ice_Coffee wrote:well if audi are to be believed, then strictly no other products than
My dealer gave me this:
I also occasionally use BG 44k, no sure if it's available over there. I tend to only use fuel additives before changing the oil as the detergent agents & deposits break down the oil.
P_G
Post by P_G » Sat Jan 29, 2011 9:40 am
Cheers for the help
Dougie
IIRC if you go to Winns website there is a dealer locator on it. I use Andrew Page motofactors in Newcastle for mine.
Brooner
Post by Brooner » Sat Jan 29, 2011 10:14 am
d10uug wrote:P_G wrote:I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
Cheers for the help
Dougie
i used my loacal garage the can order it and have it there in a couple of days as this is normaly a motor trade product i think
PetrolDave
Post by PetrolDave » Sat Jan 29, 2011 11:40 am
I get Wynns DIP3 from a motor factor in Eastleigh.
Ice_Coffee
Post by Ice_Coffee » Sat Jan 29, 2011 10:54 pm
If you decide to use the audi stuff these are the instructions, interestingly it also notes how to tell if you need to do this or not (provided you have VCDS)
A20LEE
Post by A20LEE » Sun Jan 30, 2011 8:27 am
I used to use it on my corrado and later found it caused the seals on the injectors to bond themselves to the head and injectors and had to have a whole new fuel rail as it was bent trying to get the thing off. I was told not to use it again, it was the slick 50 version i used every 6000 miles.
Ice_Coffee
Post by Ice_Coffee » Sun Jan 30, 2011 10:12 am
A20LEE wrote:I used to use it on my corrado and later found it caused the seals on the injectors to bond themselves to the head and injectors and had to have a whole new fuel rail as it was bent trying to get the thing off. I was told not to use it again, it was the slick 50 version i used every 6000 miles.
And that is probably why we should stick to G17, regarding fuel additive.
P_G
Post by P_G » Sun Jan 30, 2011 10:48 am
Use what A20Lee, DIP3 or G17?
klauster
Post by klauster » Sun Jan 30, 2011 12:24 pm
I have never done this, do you think its worth me asking the dealership parts dept to give me some to try? What price should I expect to pay?
Ice_Coffee
Post by Ice_Coffee » Sun Jan 30, 2011 2:23 pm
I would use G17 in combination with DIP 3 Aerosol as they do two different jobs, G17 cleans the injectors, DIP 3 aerosol reduces our coking problem, there is no need to use G17 unless you do the test with VCDS and fail it.
Users browsing this forum: Bing [Bot] and 217 guests
