run it again, reinspect/measure
probably won't happen til spring
it is a very simple/safe concept...
if I sound evasive, I am
it's so simple I can't believe it hasn't been done (it may have been) curently having a patent search performed
TimsterRS4 wrote:Hi Arthur... I thought you were working on something.ArthurPE wrote:I'd like to see the manual...how the system hooked up...if it's to the fuel rail, won't help the inlet valves...as someone said...will do the cylinder, piston, etc.
I am working on something to do this, there will be millions of cars, and mucho $$$ to be made...
I personally don't think deposits are an issue, but if people are willing to pay for 'scotchguard', permanent paint sealant and tranny flushes, why not make a few bucks?
it is non-corrosive, biodegradable, non-chemical/toxic and abundant
hook the system up, and drive around on the highway for an hour (or so)
should make it spotless....it will dissolve it slowly and in very small pieces, no chunks...may need 2 treatments for extreme cases
should not require an oil change afterwards
When can we get some and test it for you?
