route thru bulkhead on MY04 Audi S4 - help
mwp
Post by mwp » Sun Feb 15, 2004 10:19 am
I'm helping a friend fit a LRC100 (laser jammer) and need to feed the wire thru the bulkhead into the cabin to connect to his roadangel. When I looked under the bonnet ... woooaa no room and bulkhead not visable. Also if i try to look from the inside and find a hole that way ... everything is nailed down tight ... bl00dy germans !!
any help would be greatly appreciated.
- mark.
wombat
Re: route thru bulkhead on MY04 Audi S4 - help
Post by wombat » Sun Feb 15, 2004 11:16 pm
Hi,
I will have the same problem next weekend when I try to fit the remote laser sensor for a Snooper B6; so I'm interested to hear anyone else's experiences too.
If you haven't received an answer by then I'll let you know what I discover when the car goes up on the ramp.
Darren
[img]images/graemlins/audiS4black.gif[/img]
mwp
Post by mwp » Wed Feb 18, 2004 11:48 pm
I got this from scoobynet ...
Well remove wiper arms, scuttle panel trim (trim around battery and brake fluid reservoir) and remove trim at bottom of windscreen(3 clips and then unclip from windscreen - sounds easy but don't break the trim...... or the screen).
At drivers side corner, remove square plastic box cover (torx screws) and this'll give you access into the car, you can unclip the ECU for more access. You'll need to remove the trim below the steering column, above the pedals to get to the other side.
Users browsing this forum: No registered users and 11 guests
