TV Screen...
Alan
TV Screen...
Post by Alan » Thu Feb 05, 2004 12:46 pm
Does anyone know how to enable the TV screen in an RS6 whilst on the move?
I ask as I want to fit a DVD player in the glovebox for the other half to amuse herself with whilst on a journey, surely it must be possible using VAG-com or something? [img]images/graemlins/confused.gif[/img]
My installer tells me that normally the patch lead supplied does this but on Audi's it doesn't?
Alan [img]images/graemlins/grin.gif[/img]
B78 RS4 Avant
Porsche 996 GT3RS
Renault Megane R26R BDM 270bhp
bjacks
Re: TV Screen...
Post by bjacks » Thu Feb 05, 2004 12:51 pm
I believe you need to put a switch in the GALA circuit (the one that tells your nav that you're moving at a certain speed). This will prevent the NAV from working but you'll be watching a DVD anyway.
I think I read it on TVWIZ.NET
Ben
peterb
Re: TV Screen...
Post by peterb » Thu Feb 05, 2004 1:51 pm
Certainly it is the speed signal which needs to be disconnected to enable picture whilst on the move. This will also disable the GALA facility. I don't think it will stop the Nav from working, but it may render the dead reckoning somewhat suspect. Dead reckoning should allow the Nav system to function for a while in the absence of satellite reception. The Nav+ apparently incorporates gyros to support DR, and may possibly use the speed signal to supplement to gyro data.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Alan
Re: TV Screen...
Post by Alan » Thu Feb 05, 2004 3:42 pm
Hmmm.
Thanks guys, so if I understand correctly, the speed signal needs to be turned off.
Would this be a permanent thing i.e. all the time or is there a way of doing it ONLY when using the TV or DVD?
Thanks for the link Ben, I'll have a trawl over there [img]images/graemlins/boots.gif[/img]
B78 RS4 Avant
Porsche 996 GT3RS
Alan
Re: TV Screen...
Post by Alan » Thu Feb 05, 2004 4:01 pm
Excellent, found just what I was looking for at TVWIZ...cheers chaps! [img]images/graemlins/jump.gif[/img]
B78 RS4 Avant
Porsche 996 GT3RS
bjacks
Re: TV Screen...
Post by bjacks » Fri Feb 06, 2004 10:31 am
Let us know how you get on as it's something that I may be interested in [img]images/graemlins/wink.gif[/img]
Ben
Alan
Re: TV Screen...
Post by Alan » Fri Feb 06, 2004 11:59 am
Will do!
B78 RS4 Avant
Porsche 996 GT3RS
dog
Re: TV Screen...
Post by dog » Fri Feb 13, 2004 12:56 pm
In the RS4 the GALA wire is a white and blue wire that is in position 1 in a black 8 pin plug.
bjacks
Re: TV Screen...
Post by bjacks » Fri Feb 13, 2004 5:11 pm
Might you have you put a switch in yours then? [img]images/graemlins/wink.gif[/img]
S4 OXON
Re: TV Screen...
Post by S4 OXON » Sat Feb 14, 2004 12:19 am
Just found a site which may help all tho its for a A2 [img]images/graemlins/confused.gif[/img] www.audi-a2.co.uk/tvlock.pdf hope it helps a bit [img]images/graemlins/thumbs.gif[/img]
dog
Re: TV Screen...
Post by dog » Thu Feb 19, 2004 10:05 am
I am going to do it in 3 weeks, when I get home from my exile....
Joules
Post by Joules » Thu May 20, 2004 5:35 pm
I did this to my RS and it was OK but I lost the ETA details on the Sat Nav+ and gained an error on the instrument cluster that meant the top part of the DIS did not show track info etc. Hence I have now re-connected as per std. You could use a switch but I reckon the error need a power off reset to clear??
C63, (C6) RS6 Avant, (C5) RS6 Avant, (B5) RS4 Avant, RS2 Avant, S4, S2, EVO IX 400 BHP
dog
Post by dog » Sun May 23, 2004 4:22 am
I have done it on mine, put a switch into the gala wire and it is working fine.
Joules
Post by Joules » Sun May 23, 2004 9:41 am
dog wrote:I have done it on mine, put a switch into the gala wire and it is working fine.
I must have cut the wrong wire ..... Opps
Scotty
Post by Scotty » Sun May 23, 2004 10:23 am
On after market head units there's normally a cable to the handbreak switch. Have you tried driving with this up a notch to see if it still works? If so you can then disable this cable and still have all the other functionality.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
Return to “Electrical”
