LED front lights any final conclusions?
Rick_RS4
Post by Rick_RS4 » Tue Dec 28, 2010 8:33 pm
ok i have read and read and read on the led saga,
i have bought some 501 led canbus sidelights these work great no errors, i have some canbus led 382 for the DRLs but these throw up a dipped beam failure, i dont really want to put resistors in, but if thats the only solution then i will, i have read that you need 50w 10R resistors,
next are the fog lights as i have the 'come home' function on and dont like yellow light
so i thought we could compose a list of lights that work and where we bought them from etc to help with the numerous posts and questions
THESE WORK
http://www.car-mod-shop.co.uk/WHITE_CAN ... ight_bulbs
THESE DONT
http://www.car-mod-shop.co.uk/Canbus%20 ... egory_id=0
NOT TRIED THESE YET (waiting for resistors as not canbus)
http://www.car-mod-shop.co.uk/LED_Fogli ... ight_bulbs
Norre
RE: LED front lights any final conclusions?
Post by Norre » Tue Dec 28, 2010 10:32 pm
Welcome to the LED jungle ;)
I bought these http://www.car-mod-shop.co.uk/WHITE_CAN ... ight_bulbs
from ebay yesterday. I have tried 3 types of lamps, and no one works without resistors yet. Waiting for my ebay order, hopefully they will work.
As for the DRL's i have bought lamps from ebay ad severeal other places, no one worked without resistor.
I xenon converted my fogs, 6000k. Looks awesome!
I also made a order on ebay for error free license plate bulbs, cause the ones i bought here in sweden did not work. The package said for cars with canbus such as audi, bmw, porsche etc. But that text didn't help ;)
Daytona grey Saloon Wrapped in matte white - Eisenmann exhaust - Clear corner mod - Carbon wrapped roof and trim around grill - Cupra lipp - K&N High Flow Filter - Re-mapp is on it´s way
Rick_RS4
Post by Rick_RS4 » Tue Dec 28, 2010 11:00 pm
will be good to see your results, have you used a resistor? if so which one? on my link it says These will fit
- Audi, VW, Seat, Skoda etc NON-LED DRL lights does this mean they dont work or they dont fit the newer led drls?
PetrolDave
Post by PetrolDave » Wed Dec 29, 2010 5:26 pm
I helped a member on here get LED DRL's working a couple of years back, we had to fit resistors.
The other thing to bear in mind is that LED bulbs are polarity sensitive but incandescent bulbs are not, so:
- if an LED bulb flashes that's almost certainly the bulb failure warning system working.
- if an LED bulb doesn't light up at all, check the polarity - and don't assume that the left and right bulb holders will be wired the same way round, I've heard of many instances where they're different.
Rick_RS4
Re: RE: LED front lights any final conclusions?
Post by Rick_RS4 » Wed Dec 29, 2010 6:06 pm
PetrolDave wrote:I helped a member on here get LED DRL's working a couple of years back, we had to fit resistors.
do you think then that my 382 drl bulbs might work correctly if i turn them round, they were lit before but the light on the display was on to , could turning the drl bulb round make a correct circuit?
my next problem is the fog lights, they are 24 led ones so i would say 1w per led
55w normal - 24w led = 31w resistor but im unsure which one to buy
PetrolDave
Post by PetrolDave » Wed Dec 29, 2010 6:28 pm
Rick_RS4 wrote:do you think then that my 382 drl bulbs might work correctly if i turn them round, they were lit before but the light on the display was on to , could turning the drl bulb round make a correct circuit?
If the LED bulbs lit up, then it's the bulb failure warning kicking in - if they didn't light up then it's worth trying them the other way round (when the bulb failure warning will probably kick in and they'll flash).
Rick_RS4 wrote:my next problem is the fog lights, they are 24 led ones so i would say 1w per led
You need a resistor that makes the combination of the bulb and the resistor draw not much less current than the normal bulb would.
1W per LED is very unlikely, I suspect they will draw much less than that (I have some 3W LED bulbs at home that produce more light than a 50W halogen bulb).
So first check how much current the LED bulbs actually take (measure it with a multimeter).
A 55W bulb will draw about 4.5 amps from 12V so you'll need a resistor to make up most of the difference. Let's say the LED draws 0.5 amp, so you'll need a resistor that draws 4 amps from 12 volts, i.e. 3 ohms (R=V/I).
Rick_RS4
Post by Rick_RS4 » Wed Dec 29, 2010 7:00 pm
right, you have just confirmed what i have just read, im going to order a couple of these
http://uk.rs-online.com/web/search/sear ... &R=0136200
and see how i go,
thanks for the help
Norre
Post by Norre » Wed Dec 29, 2010 9:16 pm
and see how i go,
thanks for the help
I have those resistors, they get really really hot! Think about that when you mount them, i didn't the first time, almost cost me a new headlamp...
Rick_RS4
RE: Re: RE: LED front lights any final conclusions?
Post by Rick_RS4 » Wed Dec 29, 2010 10:07 pm
those are for the fog lights so will be mounted behind the fog on a metal plate or behind the bumper on the chassis, for the drls im going to use a 50w 24r or if that doesnt work a 10r, from what i have read,
thanks for the heads up though
Norre
Post by Norre » Wed Jan 05, 2011 1:50 pm
I have tried out ALOT of bulbs for license plate light, DRL:s, and parking light.
Here are my results.
Don't work:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT (litt up but warning)
Works:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT (warning for about 2 sec, then gone)
http://cgi.ebay.com/ebaymotors/V-LEDS-T ... 336351f76e (with resistor)
Xenon HID on fog lights works, get a canbus kit to be sure.
Next bulb i will test for parking lights are these;
http://www.ecstuning.com/Audi-B7_RS4--V ... /ES252273/ (built in resistor).
Rick_RS4
Post by Rick_RS4 » Wed Jan 05, 2011 11:33 pm
the 501 bulbs i use above work like the ones you are going to buy from ecs
Rick_RS4
Post by Rick_RS4 » Thu Jan 06, 2011 11:20 pm
ok so little update i fitted the resistors to the DRL lights, and they look awesome (if i do say so myself) much better than yellow light.
iv not checked how hot they get yet will try that out tomorrow after a run. iv read these are cool running so will be fine to mount inside the headlight unit,
sidelights
http://www.car-mod-shop.co.uk/WHITE%20C ... egory_id=0
(no resistor required)
DRL
http://uk.rs-online.com/web/search/sear ... 4r&x=0&y=0
Dipped + Sides (nothing required)
Dipped + Sides + Fogs
(not done resistors yet for these)
Users browsing this forum: No registered users and 149 guests
