Full Closure from KeyFob
About to take ownership of a 2004 RS6. Windows fully close on turn and hold when key in driver's door lock but not when holding down lock button on either keyfob.
Can a Dealer program this to work?
Also when closing using the key one of the rear windows (occasionally both) will decide to open up as if sensing an object in the way. Takes a few goes to close it. Sensor need replacing?
Pretty sure the mirrors don't dip on reverse!
I wanted them to auto fold on closure but they appear only to be connected direct to the switch
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks
. Maybe RS5 or S5 Hatchback to come...
- PetrolDave
The nearside mirror only dips on reverse IF you have memory seats AND have the mirros adjustment switch turned to the passenger mirror.RS6Steve wrote:Pretty sure the mirrors don't dip on reverse!
There is no auto-fold function on the mirrors - only manual fold, and then only with the ignition on and if you're doing less than 5mph.
...and for anyone with memory on the B7 RS4, the dipping logic thinks you're in a LHD car, so you have to point to the driver's side if you want the passenger mirror to dip!PetrolDave wrote:The nearside mirror only dips on reverse IF you have memory seats AND have the mirros adjustment switch turned to the passenger mirror.
2007 Daytona RS4 Avant
- PetrolDave
You're probably right, but it's so unimportant that I've never investigated it. Memory was never an option in the UK (I had to go through Audi exclusive) so they probably reached for the only part / coding they had to handPetrolDave wrote:Sounds like your memory module has been incorrectly coded or wired.
- PetrolDave
Certainly when that same module is fitted to other B7s (A4 and S4) it's coded/wired correctly so that the mirror switch must be turned to the nearside - I'd get a VAG-COM expert to check the coding, you might be able to get it working correctly for little/no cost.
