When my rns-e unit gets hot I am getting the following message:
DVD unreadable or
not properly inserted.
So I take the disc out. Replace - still the same
So I get the second of the genuine 2007 Audi discs and put that in.
Invariably that works, but sometimes I still get same message.
So I try an audio CD and sometimes that works and sometimes it doesnt
Then I might use the CD lens cleaner and you guessed it sometimes it works and sometimes it does not.
What the hell is going on here?? Weak laser? Anyone had identical problems and found a fix?
Who can change the lasers on these things??
This is driving me mad.....
- PetrolDave
RE: This is driving me mad.....
You can get spares from members rabbit or Haaggie on www.audiforum.us - one is in Belgium and the other in The Netherlands.
Coxall8395
thanks. Will ask them what part is causing the problem
- PetrolDave
It's the laser itself - it gets weaker with time and becomes unable to read the second layer on the map DVD, but can still read CDs which are only single layer.
Coxall8395
thanks. That explains it.
