Due a service
Doug_S2
Trader (Expired)
Post by Doug_S2 » Fri Nov 19, 2010 9:18 am
We use Audi ll3. Or we get in whatever the customer wants to use.
http://www.MRCtuning.com
P_G
Post by P_G » Fri Nov 19, 2010 10:25 am
On a slightly related question, anyone know how you remove the oil filter from the housing cap. I thought itwas a simpli twist and pull but mines not having any of it.
Last bit to do as well!
sonny
Post by sonny » Fri Nov 19, 2010 12:46 pm
P_G wrote:9.6 litres for the V8. you don't have to but I change my plugs every other service and there is some gain from doing that.
Odd one as I thought this too, but at last oil and filter changed the car took well over 10 litres (possibly even close to 11 from what I can remember (on digital gauge used). The car was on the ramps for over an hour so enough time to let all the oil drain out.
ArthurPE
Post by ArthurPE » Fri Nov 19, 2010 4:05 pm
the most mine has taken (drained for >30 minutes and 'rocked') was ~9.5 liter, maybe 9.75
filled to 80% of fill to full
11 sounds like a lot
scaghead
Post by scaghead » Fri Nov 19, 2010 8:25 pm
on the same note mine took the full 10 litres today.. i will check in the morning what height that is on the dipstick..
ArthurPE
Post by ArthurPE » Fri Nov 19, 2010 11:43 pm
don't forget to check it hot ~ 5 minutes after shutdown
the volume changes a good bit with temp
20C 888.1 kg/m^3
100C 840.0 kg/m^3
so the since the mass stays the same the volume gets 888/840 ~ 1.06 0r 6% larger
so 10.5 liter cold ~ 11.1 liter hot...1/2 the dipstick range of ~ 1 liter...
I always put in 9.5 and toss a liter in the trunk
after I drive it the first time I check the level and top off to 80% fill to full...
adsgreen
Post by adsgreen » Sat Nov 20, 2010 12:58 pm
Hadn't thought about expansion... Always did wonder why they specify hot in the manual.
ArthurPE
Post by ArthurPE » Sat Nov 20, 2010 11:14 pm
just checked my oil consumption
same spot in the garage
car fully warm, oil >90 C
<1/4 liter in ~4000 miles
started at 3/4 full, now at top of hatch marks
since I do a 5k change should not need topped off
<1 liter per ~16000 miles
adsgreen
Post by adsgreen » Sun Nov 21, 2010 7:34 pm
That seems awfully low for a high output N/A revvy engine.
ArthurPE
Post by ArthurPE » Sun Nov 21, 2010 9:30 pm
adsgreen wrote:That seems awfully low for a high output N/A revvy engine.
it is what it is...I'm anal when it comes to stuff like this... :)
not really surprising to me
large capacity (low dilution concentration)
small engine 4.2 liter
oil cooler and great filtration
excellent blow-by capture system
very good synthetic oil
never push until warm
the high compression helps, good ring seal
iirc there was a poll and many guys use very little oil...
my 951 drinks it 1 liter/2000 miles
e46 M3 ~1 liter/3000 miles (140k miles though)
no leaks, only engine consumption
neckarsulm
Post by neckarsulm » Sun Nov 21, 2010 10:03 pm
What's your view on Platinum 5w/40 in B7?
wellzieRS4
Post by wellzieRS4 » Tue Dec 07, 2010 12:06 am
Got it serviced today the have put 9Lt of oil in, is that enough?
ArthurPE
Post by ArthurPE » Tue Dec 07, 2010 4:14 am
wellzieRS4 wrote:Got it serviced today the have put 9Lt of oil in, is that enough?
only one way to know...
check it when hot, level ground, 5 minutes after shutdown
check it a few times to get consistent readings
my guess, you'll need 1/2 liter or so
fill to 3/4 fill to full marks
ArthurPE
Post by ArthurPE » Tue Dec 07, 2010 4:16 am
P_G wrote:On a slightly related question, anyone know how you remove the oil filter from the housing cap. I thought itwas a simpli twist and pull but mines not having any of it.
did not see this earlier, twist and pull
sometimes cock it at angle angle to get one side started/lifted
obviously wrap the filter with a rag :D
P_G
Post by P_G » Tue Dec 07, 2010 9:52 am
Probably not, that would be at min level. 9.6-10 litres is correct. I supplied 3x4 litre Castrol SLX III last week to my dealer and they returned just over 2L.
Users browsing this forum: Google [Bot] and 1571 guests
