Red tyre pressure warning - won't reset
rjkflyer
Post by rjkflyer » Mon Nov 29, 2010 5:00 pm
Have got the red tyre pressure warning on (maybe due to very cold weather and not driving car for two weeks). All tyres equal and all down a few psi due to intense cold.
However, cannot seem to reset it. The SET button on the RS steering wheel will only cycle between the big full screen red flat tyre and the lap timer. I cannot seem to get to the menu to permit me to resst the tyre pressure warning system.
I did read something regarding it taking 20 mins to work itself out - and I may not have driven it that long.
However, anyone know if i have a fault, and if so what to do?
Thx.
sumdy
RE: Red tyre pressure warning - won
Post by sumdy » Mon Nov 29, 2010 5:29 pm
I had the same happen a while back.
Are you trying to reset with the engine running? if so try with ignition on but dont start her up.
This worked for me.
klauster
Post by klauster » Mon Nov 29, 2010 5:40 pm
check its not a tyre with a line through it, if this is the case its what happened to mine and you require a new sender/receiver which could have gone faulty...
Lewy1000
Post by Lewy1000 » Mon Nov 29, 2010 5:46 pm
I had same problem - all typre pressures spot on but the warning wouldnt go off no matter what I tried. Luckily it was booked in for some work at the dealers a couple of days later so they reset it for me.
Dom81
Re: RE: Red tyre pressure warning - won
Post by Dom81 » Mon Nov 29, 2010 6:06 pm
sumdy wrote:I had the same happen a while back.
This worked for me.
My thoughts exactly - I had the same problem after a tyre change and eventually figured this out
2007 Daytona RS4 Avant
yorkie
RE: Re: RE: Red tyre pressure warning - won
Post by yorkie » Mon Nov 29, 2010 6:26 pm
I had exactly the same last Monday.
Ended up going to the dealer who found a nail in front offside tyre.
Reset fine after tyre repaired.
PetrolDave
Re: Red tyre pressure warning - won't reset
Post by PetrolDave » Mon Nov 29, 2010 7:32 pm
rjkflyer wrote:all down a few psi due to intense cold.
If the pressures are down enough they will be below the warning (yellow) threshold, hence it will show a red warning. I think (with the standard coding) that happens at 2.2bar.
rjkflyer
RE: Re: Red tyre pressure warning - won
Post by rjkflyer » Mon Nov 29, 2010 8:28 pm
And the right answer is: reset with ignition on but without engine running. All fine now.
Thanks people!
P.S. a failed sender yields a YELLOW tyre with line through it.
drcarrera
Post by drcarrera » Mon Nov 29, 2010 8:31 pm
I had a red warning last week, purely due to the cold dropping the pressures. Quite surprised they dropped that much, TBH.
Chris
06 Daytona RS4 Avant (B7)
ianchastney
Post by ianchastney » Tue Aug 29, 2017 9:21 am
Hi Guys,
Thank you very much for your help.It worked. I wonder how much Audi were going to chage me for this ???
It takes seconds when you know what to do.
Thank you Ian
Users browsing this forum: No registered users and 144 guests
