When I get in the car in the morning and touch the volume control on the radio it turns the volume up to a ridiculous level. I then turn it down and it mutes. You touch it either way it either mutes or turns right up.
I cannot see why it does this, the solution found is to bear the noise for 10 seconds or so then you can slowly turn it down.
Has anyone else experienced this?
Radio Volume going crackers
Re: Radio Volume going crackers
Check the vlume setup menu.
Try setting the default volume to a low level and see if that helps.
Also, does it matter if you listen to the CD rather than the radio ?
Just wondering if you have Traffic Announcements enabled.
Sounds a funny one, so might be worth seeing if vagcom gives any audio errors. If you don't have vagcom that might mean a trip to the dealers to see if they will plug it in and diagnose it for you.
Good luck !
Cheers,
John.
Good luck !
Cheers,
John.
Too many toys, not enough time
tartan_rob
On a similar note, I've found that the volume increments are really large on my stereo (Bose syphony system) and when the TA kicks in it is REALLY loud, even though I've turned the TA volume down to 1 in the settings. Anyone had this problem?
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten
Users browsing this forum: No registered users and 10 guests
