engine managemet light?
- tonyredmond
2 days after fitting a full miltec to my s4 cab, bought from
a member on the forum, ive got the engine light permanantly
on ,is this just coincedence or is this a common thing , the
garage who fitted it said they had to do some mods to it as
it didnt fit that well , just seems strange it happened 2days
after and not sraight away, it all drives well, any ideas?
RE: engine managemet light?
Sounds like a lambda probe fault, my just be a loose connector
•••MyProtein Discount code MP486494•••
- BlingBling
More than likely it is a cold start fault.
- tonyredmond
thanks guys it came on about 10 minutes when the car warmed up,
would this fault show on a v/com?
- tonyredmond
fault code 2nd bank cat not warming up properly, as i said the sensor was moved slightly
so would spacers be the solution or can the light be removed somehow?
- BlingBling
I had that after removing the pre-cats. IIRC it can be removed permanently
A remap could take care of this sort of fault codes
Users browsing this forum: No registered users and 46 guests
