Newbie needs help buying 07 / 07 RS4
jj0007
Post by jj0007 » Wed Nov 10, 2010 9:45 pm
Hi. I'm new here. Previously owned a 5.6L V8 Ford in Australia, but now that I'm in the UK I'm looking to get my hands on one of these RS4 beauties.
Are there any common major problems I should look out for when shopping for one of these?
Also I keep seeing the term FASH appear in ads. What does this stand for?
When are the minor and major service intervals due?
Thanks in advance for the help.
RE: Newbie needs help buying 07 / 07 RS4
Post by HYFR » Wed Nov 10, 2010 9:48 pm
fash = full audi service history
no major issues with the cars bar the DRC
jj0007
Re: RE: Newbie needs help buying 07 / 07 RS4
Post by jj0007 » Wed Nov 10, 2010 10:10 pm
aka_dk wrote: no major issues with the cars bar the DRC
This probably sounds really stupid, but how can you tell if there is a problem with the DRC? Is there any tale tale signs I should pay particular attention to during test drives?
RE: Re: RE: Newbie needs help buying 07 / 07 RS4
Post by HYFR » Wed Nov 10, 2010 10:23 pm
knocking sound ... really bad handling
look for misting, moistness on the outside of the shocks (if you look inside the arch)
Audi should cover DRC up to 5 years via goodwill assuming FASH
jj0007
Post by jj0007 » Thu Nov 11, 2010 2:27 pm
What are the service intervals for the B7 RS4?
What grade fuel do they use in stock form?
PetrolDave
Re: RE: Re: RE: Newbie needs help buying 07 / 07 RS4
Post by PetrolDave » Thu Nov 11, 2010 8:07 pm
jj0007 wrote:What are the service intervals for the B7 RS4?
1 year or 10,000 miles (whichever comes first) on fixed servicing. If it's on variable servicing (up to 2 years or 20,000 miles) then get it moved onto fixed servicing.
98 EU RON (93 US MON/RON average). So stick to super unleaded in the UK. You can use regular (95) if it's that or run dry, it won't cause any damage as the timing will be adjusted by the knock sensors - but you will be well down on power.
ArthurPE
RE: Re: RE: Re: RE: Newbie needs help buying 07 / 07 RS4
Post by ArthurPE » Thu Nov 11, 2010 11:57 pm
mine is marked:
91 (US) (R + M)/2
95 RON
probably because 93 is not available in some areas/states
Users browsing this forum: Bing [Bot] and 201 guests
