Cheap mites break pads
bigjocky
Post by bigjocky » Thu Nov 04, 2010 10:16 am
Fitted these pads £80.00 for front n back, however, when breaking, immediately at the point of stoping dead, the pads seem to create a shudder on the disc, it's very slight, but slightly annoying.,! Anyone having a similar problem,& can it be cured???? Cheers
bigjocky
RE: Cheap mites break pads
Post by bigjocky » Thu Nov 04, 2010 10:17 am
Miltek pads,,,, sorry spelling mistake!!!
RS6Steve
Post by RS6Steve » Thu Nov 04, 2010 11:19 am
Don't you mean mintex?
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
scooby-tc
Post by scooby-tc » Thu Nov 04, 2010 11:32 am
haha was going to say,Miltek don't make brakes.Definately Mintex which for the record are actually quite good although i prefer Pagid
2003 RS6 Avant (NOW SOLD)
Post by Shoppinit » Thu Nov 04, 2010 11:47 am
I haven't fitted mine, but a friend has on his S6. Same problem. Resolved by carving a slight chamfer on the leading edge of the friction material.
Fizmo100
Re: RE: Cheap mites break pads
Post by Fizmo100 » Thu Nov 04, 2010 5:40 pm
Shoppinit wrote:I haven't fitted mine, but a friend has on his S6. Same problem. Resolved by carving a slight chamfer on the leading edge of the friction material.
Do you have any pics of this? How much or a chamfer are we talking about here? I have Mintex pads on at the mo and get the same little graunch at the end of braking. It's no big deal, but as I'm about to fit new pads I might as well have a go at solving the judder while I'm at it. What did you use to chamfer the pad - I'm guessing a file would do the trick?
RE: Re: RE: Cheap mites break pads
Post by Shoppinit » Thu Nov 04, 2010 5:49 pm
Don't have any pics. I'll ask the question. But a small chamfer of about 1mm should be enough to tell you if it's going to work or not. I'll do it on mine before putting them in.
Daveperc
Post by Daveperc » Thu Nov 04, 2010 6:58 pm
Surely if you only chamfer 1mm then after 1mm wear it will be gone again - you need to chamfer the full working depth of the pad unless you are going to repeat the process on a regular basis???
Or you could buy OEM pads I guess!!
Post by Shoppinit » Thu Nov 04, 2010 7:03 pm
The reason I bought the mintex pads is because the OEM contain a time bomb that destroys your disks (the infamous metal pins half way through).
And the 1mm was to test whether the chamfer would be effect before hacking half of them away, hence the
scoobylaw
Post by scoobylaw » Thu Nov 04, 2010 7:11 pm
my pads havent arrived yet. Am i right in thinking all the front 8 pads are the same, so i'll just have to file one side on 4 pads and the other end of the pads on the other 4?
hope ther above makes sense ;-)
Post by Shoppinit » Thu Nov 04, 2010 8:23 pm
That's what I am going to do.
bigjocky
Post by bigjocky » Fri Nov 05, 2010 10:18 am
Is it caused because of the pad material? Or the shape??
Gravitypilot
Re: RE: Re: RE: Cheap mites break pads
Post by Gravitypilot » Fri Nov 05, 2010 10:43 am
bigjocky wrote:Is it caused because of the pad material? Or the shape??
on this subject guys....
does the rs6 warn when the brakes pads are low?
03 Mugello Pearl Avant 32K
MTM Tuned, Vreds, Miltek 520+ :-)
Need any parts? just give me a shout on PM
RE: Re: RE: Re: RE: Cheap mites break pads
Post by Shoppinit » Fri Nov 05, 2010 11:04 am
Yes, but not before the damage is done.
Daveperc
Post by Daveperc » Fri Nov 05, 2010 12:40 pm
That's what the mischeivous pins are for. The key to remember is that as soon as they come on, you need to get the pads changed - if not, then you will start to score the disc. If you keep driving it then gets worse.
Of course, the scoring does mean that you actually get slightly more wear from the next set of pads as they don't wear so much where the pins are!
No pins = no warning!
Dave
Users browsing this forum: Bing [Bot] and 104 guests
