Finally took delivery of my little beauty
I can barely sleep with her sitting on the driveway.
Although one question, took her for a drive earlier and didn't really notice any real power difference after 5K rpm. This is probably a stupid question, how noticeable is this really.
Should it smack you in the face?
RE: Finally took delivery of my little beauty
congrats mate and welcome
I would say you can notice it but it is not a smack in the face....I would describe it as an extra search but you can def feel it
Its more noticeable in 2nd or 3rd.
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
just read that back!!
extra surge I meant to say!
I'm a relatively new owner, but in my experience I noticed little or no surge until I got a replacement air filter at MRC last week. Even then, it's quite a subtle kick, not like a turbo, but it just keeps going and going....
i would say subtle kick probably best describes it.....good luck with the motor fella
- Steve_C
- Top Gear
Yes, as extra surge sums it up well. Similar (but slightly less) to the surge you get in a Honda Type R with VTEC but nothing like as much as a turbo kick.
Gone to the dark side
There are 2 things you are feeling - in the 1st 3 gears you do not getting full throttle (even though your foot is on the floor) until you hit 5000-5500rpm. In 4th to 6th gears you have WOT through the revs but at 5000 you get the cams changing and this gives you a rise in torque and another 'kick'. If you are used to turbo cars you would not call it a kick!
http://www.MRCtuning.com
Re: RE: Finally took delivery of my little beauty
Great information Doug thanks!Doug_S2 wrote:There are 2 things you are feeling - in the 1st 3 gears you do not getting full throttle (even though your foot is on the floor) until you hit 5000-5500rpm. In 4th to 6th gears you have WOT through the revs but at 5000 you get the cams changing and this gives you a rise in torque and another 'kick'. If you are used to turbo cars you would not call it a kick!
"100 things you didn't know about the B7 RS4" by Doug@MRC.....I'd buy it!
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
Good info - can we clarify - if you feel the kick in 1st to 3rd, which is WOT (In my car I definitely feel that) - is that then, not a fair indication/test that the flap/vacuum is working as it should be but rather you need to test in 4th to 6th to determine if it is working?Doug_S2 wrote:There are 2 things you are feeling - in the 1st 3 gears you do not getting full throttle (even though your foot is on the floor) until you hit 5000-5500rpm. In 4th to 6th gears you have WOT through the revs but at 5000 you get the cams changing and this gives you a rise in torque and another 'kick'. If you are used to turbo cars you would not call it a kick!
Because i have always felt the 'kick' at 5.5k rpm, at least in 1st to 3rd I assumed my airbox flap/vacuum system is working fine.
sorry fairly new owner if the question is too obvious
Dunc
RE: Re: RE: Finally took delivery of my little beauty
you need to test in 4th or above - it is not really a test of the flap - it is a test that there is a large enough vacuum leak to cause the car to run low timing.
what's the link between vacuum leak and low timing?it is a test that there is a large enough vacuum leak to cause the car to run low timing.
Users browsing this forum: Google [Bot] and 46 guests
