Car not running properly
bentara
Post by bentara » Sat Oct 23, 2010 7:04 pm
Hi,
I have a 2007 RS4 avant,blue 24k miles.
It has started not pulling/revving cleanly through the gears.
Driving normally its fine but when driven hard it starts hesitating/flat spotting from about 5000 rpm.
Its not misfiring or going off cylinders(i think)
I could have sworn it was a fuel filter but have put new one on,no different.
Has anyone came across this problem ?
I wonder if its fuel quality,never been able to find super unleaded to put in it but then i have done 5k miles since i got it on ordinary unleaded and it has been going fine. :?:
RS4KILLA
RE: Car not running properly
Post by RS4KILLA » Sat Oct 23, 2010 7:28 pm
airbox?
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
neckarsulm
Post by neckarsulm » Sat Oct 23, 2010 7:37 pm
wouldn't cause a misfire, tried 3 now with iffy flaps and all drive OK, owners knew no better.
Something makes me think intake manifold flap position sensors
Is StevieB still around as he told me his did this when he bought it and Audi replaced a sensor, could be intake manifold flap position sensor.
Needs a VAG COM scan for a start and then the hard bit starts!
Terry1948
Post by Terry1948 » Sat Oct 23, 2010 7:46 pm
It could be a vacuum issue so the power flap and the manifold flaps are opening and closing when vacuum builds and drops off.
neckarsulm
Post by neckarsulm » Sat Oct 23, 2010 7:51 pm
This is a corker of a thread, 2 cars, 2 new engines, both still hesitating! Fixed in the end...
http://www.rs246.com/index.php?name=PNp ... e&start=45
approved
Post by approved » Sat Oct 23, 2010 9:03 pm
i did the exhaust mod and mine did this...i put it back and it worked perfectly...
i obviously didnt do it right and caused some vacuum issue..
neckarsulm
Post by neckarsulm » Sat Oct 23, 2010 9:07 pm
indeed!
the vacuum that operates the exhaust flaps also operates the intake air changeover flap aka power flap and the intake manifold flaps.
If you disconnect the pipes from the exhaust valves but don't block them off then the vacuum pressure in the system bleeds out and is insufficient to operate the manifold flaps and the power flap.
bentara
Post by bentara » Sat Oct 23, 2010 10:02 pm
Thanks for the replies there.
I thought a bit before buying this car with no warranty,hopefully im not in for expensive engine repair at 24k miles !
I tried it up the road again,goes flat at 5k revs and does not light up at 6k as it should do.
When i got back to house and had it idling when i stab the throttle quickly on and off it makes a suction sound,dont remember hearing that before.
Its the same sound that you get when you have the air filter off an engine,(in your youth)
Is there any point in taking this car to a dealer to be charged a lot of money and find nothing or go to a decent rolling road. :?:
neckarsulm
Post by neckarsulm » Sat Oct 23, 2010 10:08 pm
Sounds like a vac leak.
Where are you based?
bentara
Post by bentara » Sat Oct 23, 2010 10:28 pm
Im in N Ireland,have a dealer 4 miles away think they are £100 per hour or there abouts.
neckarsulm
Post by neckarsulm » Sat Oct 23, 2010 10:36 pm
Buy VAG COM sharpish then!
scaghead
Post by scaghead » Sat Oct 23, 2010 10:58 pm
bentara wrote:Thanks for the replies there.
defo think it is something air/vacuum related .dont panic just yet :) like neckurslum said get it vag-commed..
bentara
Post by bentara » Sat Oct 23, 2010 11:01 pm
Sorry,What is VAG COM ??
Terry1948
Post by Terry1948 » Sun Oct 24, 2010 8:34 am
First check to see if your cars had the exhaust vac pipes disconnected if it has make sure they have been properley sealed. Vag com or VCDS as it is now called is software that allows you to interrogate the car and make changes to how it functions. It is a good investment even if you only use it to perform scans and change your headlamps to tourist mode.
PetrolDave
Post by PetrolDave » Sun Oct 24, 2010 10:08 am
bentara wrote:Sorry,What is VAG COM ??
Software for you PC and a lead to connect it to you car which lets you read and reset the fault codes on any VAG car. It can save you loads of money since you can diagnose many faults yourself without paying £100 an hour to a dealer.
Users browsing this forum: Google [Bot] and 355 guests
