A friend of mine has given me his vagcom software and USB cable (blue with LED) that has previously worked on his RS6 2003, I recently tried to use VAGCOM on my rs6 2003 plate but my laptop tells me 'inferface: found not when I set it to any of the COM port and USB port options.
Anyway I had a chat with some fellow RS246ers and it seems the cable I have needs to work as a COM port cable instead of USB in VAGCOM. My laptop runs on Windows XP and has no COM ports but 3 USB2 ports.
How can i check if i have all the drivers and i understand there is supposed to be a away get the USB to read as a COM port??? Can anyone help... I am not the most computer literate so i need a little help and i cant find the answer amongst all the reponses in this forum.
1st timer - Struggling with VAGCOM and USB cable - help pls
2003 RS6 Mugello Blue and Black Natural Leather (DRC replaced thanks to the Warranty Co)
1998 Silver 993 Carrera S = Special! Hopefully a classic for the future....Go karting for Grown ups
RE: 1st timer - Struggling with VAGCOM and USB cable - help
i think in short i need to create a virtual COM port via USB port.. where do i need to start to do this?
The cable sounds like a non genuine Vag-Com lead, if so when you connected it to the car, you need to have the ignition on otherwise it will not power up and will not be seen by the computer.
I had this on a cheap e-bay special lead.
all sorted now thanks, i had to set up the port in the correct fashion
Users browsing this forum: No registered users and 22 guests
