Fan on when off
Fan on when off
Last 2 days fan has been running after it has been switched off
Temp Gauge on 90
Just checked VAGCOM no faults coming up
Coolant temp going up to 107 degrees but gauge showing 90
Think I will try a coolant temp sensor first and let you know
fingers crossed the thermostate is OK, heater working all OK and gauge stays on 90 the whole time
Temp Gauge on 90
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
Coxall8395
RE: Fan on when off
Yeah sounds like a termo/time type switch
RE: Fan on when off
More likely to be the thermostat, I fear. 107 is quite hot for the coolant. Still, doesn't hurt to change the sender first. Will at least eliminate it.
Re: Fan on when off
I changed the coolant temp sensor first , but it turned out to be the thermostat.
RE: Re: Fan on when off
Apart from the 107 degrees no signs of overheating or anything else, needle smack bang in the middle.
Heater works coolant level spot on everything feels warm under the bonnet
I'll try the coolant temp sender tomorrow and see if that changes
Also run VAGCOM on my drive in and see what the temp reads
Measure value blocks Read the same in the cluster
Fingers crossed it's not the thermo, will have to ring Warranty Direct again
I'm curious about this - could you clarify what you mean by the fan running when it's off? If you mean you turn off the engine and remove the key and the fan still keeps running, mine does this as well... I thought it was normal, but once more I am beginning to feel the trousers turning brown...
the fan will run on until the engine is cooled down , regardless of key in ignition
Re: RE: Re: Fan on when off
I have never noticed mine run on! What should I be checking? Everything run fine, temp normalphilroach wrote:the fan will run on until the engine is cooled down , regardless of key in ignition
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks
. Maybe RS5 or S5 Hatchback to come...
RE: Re: RE: Re: Fan on when off
Lol, brown trousers if it does run and brown trousers if it doesn't in the same thread!
Were a funny bunch of paranoid petrolheads!
you need to drive it harder
I'll be the warm down I do about 1 mile from home.... Boring I know....
Steve
You switch off,get out and lock.As you walk away you can hear the fan still
running.This is supposed to happen and is normal.Fan should go off within a
short time.If the fan takes more than a couple of minutes to switch off then
you might have problems,normally thermostat related.Check under the
bonnet,overheating coolant etc.
Re: Fan on when off
Hope I'm wrong but very likely to be thermostat.marmite wrote:Last 2 days fan has been running after it has been switched off
Temp Gauge on 90
Re: RE: Re: RE: Re: Fan on when off
RS6_Dave wrote:Were a funny bunch of paranoid petrolheads!
The fan seemed to be on full stage after a short journey
Did it Thurs, Fri and over the weekend and then this morning
Got home tonight and nothing
Just never noticed the fan so loud when I get out the car, new fan been fitted July
Thermostate done 3 weeks ago with Cambelt
Going to monitor, but was driving me mad
Users browsing this forum: philS2 and 131 guests
