Crazy fuel consumption - what can it be?
kaisersolsay
Post by kaisersolsay » Wed Sep 29, 2010 6:15 pm
Good call Paul!
Ceveman73
Post by Ceveman73 » Thu Oct 07, 2010 12:10 pm
Right, update...
I am slowly going through the suggestions from everyone by way of elimination until I get to the bottom of this. Have eliminated a leaking fuel tank as the car hasn't been driven for 2 weeks and fuel level is the same.
I went through the pain of replacing the new Denso IK22 spark plus with the standard NGKs, as well as checking the air box and MAFs for dirt or contamination from my new K&N filters. The airbox was squeaky clean, MAFs the same and there is no sign of oil residue from the filters anywhere.
What I did find though is that the new Denso plugs, which have done under 200 miles were already totally black on the tips and thread which doesn't look right. Could this suggest that the plugs were the issue, or a black plugs the sign of something else?
I will drive it this weekend to see if there's any improvement. If it still drinks fuel it has to be either a faulty MAF or a faulty fuel tank sensor.
Mart.
C6 RS6 Plus with a few sensible mods...
Post by Shoppinit » Thu Oct 07, 2010 12:14 pm
Black plugs are not a good sign. Sign of rich running. You are going to need to put the car on the vagcom to see what's screwed up. Could be MAFs (My money is on these) or lambda sensors. These are the most likely culprits.
They shoudl look ilke this:
DAylward
Post by DAylward » Thu Oct 07, 2010 12:17 pm
black plugs are a sign of overfuelling ( which you have established already by your MPG) it could be a leaky seal on an injector flooding the engine while running
2003 RS6 Avant
Avus Silver
KWv3 Coilovers
Hotchkiss ARBs
Wagner carbon fibre intercoolers
Milltek resonated cat back
20" C6 RS6 alloys
Kenwood multimedia centre
Unit 20 engine and gearbox remap
Post by Shoppinit » Thu Oct 07, 2010 12:19 pm
Cold start device? Could it be that your temperature sender is telling the ECU that the engine is cold? Is the temp OK on the dash?
TechNick
Post by TechNick » Thu Oct 07, 2010 12:56 pm
If the MAFs are still possible suspects after further testing, and you don't have access to VAG-COM to log trim values, etc., then still think it would be worthwhile trying the quick and simple 'temporarily disconnect MAF' test, if only to help eliminate them.
My money remains on them too! :wink:
R1NGA
Post by R1NGA » Thu Oct 07, 2010 1:06 pm
Good point about temperature guage - does it show that the engine is running cold all the time? My brothers S6 had a duff coolant sensor and the car slowly became worse in terms of MPG and then difficult to start when cold. ECU was being told that engine was cold and was therefore running the thing rich as a result. £25 swap and all was right again.
Phil G
Post by Shoppinit » Thu Oct 07, 2010 1:07 pm
Most generic OBD2 readers will give you access to the air flow readings...
Ceveman73
Post by Ceveman73 » Thu Oct 07, 2010 1:59 pm
As part of the MRC health check the car was plugged into the VAGCOM for any fault codes and there were none. Wouldn't VAGCOM be able to detect a faulty MAF?
Mart.
bilko1
Post by bilko1 » Thu Oct 07, 2010 2:16 pm
Ceveman73 wrote:As part of the MRC health check the car was plugged into the VAGCOM for any fault codes and there were none. Wouldn't VAGCOM be able to detect a faulty MAF?
Mart.
MAF sensors on VAG cars are a nightmare they rarely shown up as fault. You need to log the actual and expected values with a VCDS or similar it's the only way to be 100%
Ceveman73
Post by Ceveman73 » Thu Oct 07, 2010 2:24 pm
Can you elaborate on what VCDS or similar are?
Cheers!
M.
TechNick
Post by TechNick » Thu Oct 07, 2010 10:23 pm
Ceveman73 wrote:Can you elaborate on what VCDS or similar are?
VCDS is the new name for VAG-COM diags software - see http://www.ross-tech.com/ for more info.
300gnspitzer
Post by 300gnspitzer » Fri Oct 08, 2010 8:41 am
I had my car serviced at MRC yesterday,tthrew the K&Ns away and as if by magic
averaged 21,2mpg on the fairly steady ride home in the traffic.
Similar ride there , 17mpg
Ceveman73
Post by Ceveman73 » Fri Oct 15, 2010 1:00 pm
Right - since changing the plugs and carefully re-installing the airbox nice and snugly, fuel consumption seems to have improved dramatically! It seems strange that the plugs could makesuch a difference, but apart from a poorly fitted airbox, nothing else has been touched.
Just goes to show, it pays to use OEM parts!
Cheers for all your help.
Mart.
Users browsing this forum: Steve2003rs6 and 211 guests
