Starter button and cruise control not working....
Surfjunkie197
Post by Surfjunkie197 » Tue Sep 21, 2010 8:36 am
Got in the car yesterday and pressed the starter button (did not hold down) it coughs and nothing. Held it down car starts and feels fine. Have been driving since and you need to hold the started button down and it fires up fine. At the same time noticed the cruise control doesn't work....is this related or anyone had a similar experience. Wondering if I can fix without visiting dealer...any help appreciated.
neckarsulm
RE: Starter button and cruise control not working....
Post by neckarsulm » Tue Sep 21, 2010 8:46 am
Clutch pedal switch is faulty.
Why?
You need to press clutch to start car, having to carry on pressing starter is exactly what happens (do a search)
Cruise also needs a signal from clutch pedal switch or it wont work as it disengages when you press clutch, if it didn't when it should the results could be messy.
Easy and cheap fix in theory, any specialist should be able to do it.
Surfjunkie197
Post by Surfjunkie197 » Tue Sep 21, 2010 8:56 am
Nice one - that makes sense cheers
MB2
Post by MB2 » Tue Sep 21, 2010 3:40 pm
Was going to suggest you check brake lights as brake light switch will mess up cruise but clutch switch sounds the better culprit here !
scaghead
Re: Starter button and cruise control not working....
Post by scaghead » Tue Sep 21, 2010 6:03 pm
Surfjunkie197 wrote:Got in the car yesterday and pressed the starter button (did not hold down) it coughs and nothing. Held it down car starts and feels fine. Have been driving since and you need to hold the started button down and it fires up fine. At the same time noticed the cruise control doesn't work....is this related or anyone had a similar experience. Wondering if I can fix without visiting dealer...any help appreciated.
like neckerslum said defo clutch pedal switch, done mine about a month ago 13 quid from audi and took a numb-nut like me 5 minutes to change thanks to arthurs instructions...good luck :)
drcarrera
RE: Re: Starter button and cruise control not working....
Post by drcarrera » Tue Sep 21, 2010 9:45 pm
Ditto - mine went a few weeks ago, easy fix.
Chris
06 Daytona RS4 Avant (B7)
Users browsing this forum: Google Adsense [Bot] and 1832 guests
