What Air filter??
sonny
Post by sonny » Thu Jun 10, 2010 4:49 pm
Think MRC promote ITG, APS promote BMC on there home page. either or, there 2 very good filters, im actually interested in trying out a foam ITG number.
I had a K+N in the GruppeM, worked fine.
MB2
Post by MB2 » Thu Jun 10, 2010 5:21 pm
RS4-Chew wrote:hmm should I even ask about "insurance declaration" on a replacement (like for like, less maintenance long lasting etc etc blah blah) "non perfromance enhancing" product such as a panel filter?????
I wouldn't bother if just a panel filter. I mean if when they serviced my mum's polo they asked "shall we put in a life time filter for the same cost as the VW one ?" I am sure she would say yes & forget about it - induction kit/re-map I would class as a mod. I also think would back down anyway as did the extra 1 bhp really contribute to the accident.
RS4-Chew
Post by RS4-Chew » Fri Jun 18, 2010 11:45 am
my thoughts exactly MB2 cheers!
still waiting for it to arrive .... zzzzzzz
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
sonny
Post by sonny » Fri Jun 18, 2010 2:26 pm
I miss this baby
GruppeM filter
allan1609
Post by allan1609 » Fri Jun 18, 2010 10:41 pm
Along with a shocking return from dvla.
BMC fitlers are not too far behind with regard to shipping............. still not got it..
Mint 57plate b7 RS4 Avant in black. Also RS 1600i project!!
RS4-Chew
Post by RS4-Chew » Sat Jun 19, 2010 9:53 pm
ditto - emailed to chase ETA, no reply yet - hoping it will just turn up anyday now! The MoFos
scaghead
Post by scaghead » Sat Sep 18, 2010 8:00 pm
just fitted my bmc filter...is it me or does it make a slightly louder v8 rumble?? on a side issue while i had the air box apart i checked the air flap that operates to 90 degrees, and found the operation by hand quite stiff and presume it probably was not operating properly. re greased the centre arm section and worked it loose..[had only done this a few months ago] when i took the car out it seemed more responsive in the lower rev range...or am i suffering from that dreaded illness the placebo effect
sonny
Post by sonny » Sat Sep 18, 2010 8:42 pm
No mate, I reckon you felt the difference, when I fitted my BMC you could hear the difference. Regarding the flap, I do this on a regular basis, however make sure its only a small amount of lubrication you use as it can have the opposite effect by attract dirt and dust, making it clog up after a period of time.
Did you buy it from ECP?
P_G
Post by P_G » Sat Sep 18, 2010 9:46 pm
What do you lube it with? WD-40; Silicone grease?
scaghead
Post by scaghead » Sun Sep 19, 2010 1:50 am
sonny yes i brought it from ecp, 47 quid delivered.. p-g i lubed it with wd40. was quite surprised how stiff it was.. makes you wonder how many 4s are running about with this as an issue.did i read somewhere caldy had removed this flap and if so what are the cons..
ArthurPE
Post by ArthurPE » Sun Sep 19, 2010 2:00 am
P_G wrote:What do you lube it with? WD-40; Silicone grease?
don't use grease, it will attract dirt and get gritty/bind
clean it good with WD40, then use a small amount of something that dries into a film, Wurtz makes good stuff, but any thing 'dry' should do...
RS6chris!
Post by RS6chris! » Sun Sep 19, 2010 9:05 pm
Any one got a "numpties guide" to changing the air filter???
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
QCRS4
Post by QCRS4 » Mon Sep 20, 2010 4:18 pm
it's seems really expensive for almost nothing...
adsgreen
Post by adsgreen » Mon Sep 20, 2010 6:43 pm
WD40 is not a lubricant - clue is in the name "Water Dispersant Forumla number 40".
In fact it is the opposite and makes quite a good degreaser or to breakdown oil.
Bike chain lubricant is good but no idea if suitable for inside engines.
scaghead
Post by scaghead » Mon Sep 20, 2010 6:55 pm
you learn something new everyday...but the de-greaser wd40 defo did loosen it for me..i am surprised no-one has taken them to court as they claim on the tin it lubricates all sorts of things :?
Users browsing this forum: No registered users and 291 guests
