clutch issues...
RS4Molar
clutch issues...
Post by RS4Molar » Thu Aug 26, 2010 12:44 pm
24000 km, slight difficulty in engaging 1st gear, bite point on engagement of drive is high up ??
Yes, clutch on the way out ?
Options: 1. replacement with OEM; 2. JHM lightened flywheel/performance clutch plate; 3. Sachs kit; 4. Stasis upgrade.
Discsussion please regarding best option for me.
Molar
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
mac4RS
RE: clutch issues...
Post by mac4RS » Thu Aug 26, 2010 12:46 pm
Stasis upgrade.
I have heard of these and by all accounts quite good...
scottie1979
Post by scottie1979 » Thu Aug 26, 2010 6:22 pm
Wouldnt necessarily assume it is on its way out especially with the low ish mileage. I have these symptoms you describe also but they dont worry me. there are so many variables but the best way to tell is to test if you are getting any clutch slippage?
Certainly not unheard off for it to fail so early but fingers crossed for you.
P_G
Post by P_G » Thu Aug 26, 2010 7:06 pm
Clutch return pipe issue. When was your car registered RS4Molar?
sonny
Post by sonny » Thu Aug 26, 2010 7:26 pm
I was going to say the same. the dreaded clutch hydro pipe splitting?
Get it into a dealer pronto.
scottie1979
Post by scottie1979 » Thu Aug 26, 2010 9:17 pm
really? are there any other symptoms of this clutch return pipe issue that i should look out for.
RS4Molar
Post by RS4Molar » Thu Aug 26, 2010 10:26 pm
P_G wrote:Clutch return pipe issue. When was your car registered RS4Molar?
September 2007, Australian car.
P_G
Post by P_G » Thu Aug 26, 2010 11:06 pm
It may be a possibility?
rs4_power
Post by rs4_power » Sat Aug 28, 2010 1:51 pm
I had same issue with my Rs4, Got it checked out by dealers and had clutch replaced under warranty :)
RS4Molar
clutch
Post by RS4Molar » Fri Sep 03, 2010 10:19 am
Ok, Occasionally finding it difficult to engage 1st gear ?
Would that be the clutch plate not coming off the fly wheel for 1st to engage ?
spongy, woolly feel - 1st time on cold start, then after 20 km or so, feel cam back.
This sounds like slave cyclinder ?
Thoughts
I am thinking of bleeding the clutch fluid and investigating...
before new clutch to be put in....
Molar
mrozard
RE: clutch
Post by mrozard » Sun Sep 05, 2010 7:40 pm
i also have had clutch problems, apon driving the car hard the other day i lost the clutch travel. it was ver low. funny thing is i could still change gear and it did not slip? i pulled it up with with the top of my foot and it worked as normall. then epc light flashed??
Avus silver avant,black optics,privacy glass, tittanium pack,buckets,fbsw,ssp
sonny
RE: clutch
Post by sonny » Sun Sep 05, 2010 9:23 pm
hmmm I would say that its the split pipe, the more you use it there damage it will cause, shattered clutch and damaged fly wheel most likely.
If it gets to the point where you cant not crash the gears, turn the engine off, engage gear, turn engine on and let the car drive in that gear, only to be used in an emergency, happened to me last year in France off all places.
mrozard
RE: clutch
Post by mrozard » Mon Sep 06, 2010 3:12 pm
ok sonny, got it booked in for next monday. got a few other bits that need lookin at. think the brakes are warped! nearly new tho!
yeah cars always let you down when your far from home! fact...
part from a few niggles so far so good, thank god ive still got four months extended audi cover left!!
sonny
RE: clutch
Post by sonny » Mon Sep 06, 2010 6:49 pm
Beast that warranty mrozard
^Qwerty^
Re: RE: clutch
Post by ^Qwerty^ » Tue Sep 07, 2010 9:13 am
mrozard wrote:i also have had clutch problems, apon driving the car hard the other day i lost the clutch travel. it was ver low. funny thing is i could still change gear and it did not slip? i pulled it up with with the top of my foot and it worked as normall. then epc light flashed??
Sounds like what I had with mine. I could get it to do it 'on demand' when driving hard and could even feel it building up to it. Basically I'd be doing a bit of 'spirited' driving and then when I went to change gear the pedal would stay on the floor. 1-3 seconds later there would be an almighty bang, and the thing would start working again properly. This went on over a period of a few months, with the car going back in to the garage to have parts changed. Still never got the bottom of what caused it, but it was fixed by putting a new clutch in.
Users browsing this forum: Bing [Bot] and 178 guests
