Newbie question
ginandjuice
Newbie question
Post by ginandjuice » Tue Aug 24, 2010 11:06 pm
Hi all, Newbie question....
I,ll start by saying this is a great forum and has helped immensely in pointed me in the right direction when purchasing my dream Audi.
My question: I'm after some wheel spacers, back and front. Having done some inquiries there seem's to be lot's of choice and opinions.
if you guys could point me in the right direction to the preferred setup that would be great, also where can i purchase spacers from??
thanks
i'll post some pics also
MB2
Post by MB2 » Wed Aug 25, 2010 8:59 am
10mm each axle at the rear seems to be the general concenus if you want to be able to put 275 tyres on. If sticking to 255 it is possible get away with a bit at the front but can't comment as only have 10mm at the rear.
I got the H&R ones were great quality, fit the hub & wheel perfectly - you have to bolt through them so will get longer bolts so will either need to buy new longer locking wheel nuts or plastic caps from Audi to cover the non-locking bolts.
There are a couple of threads if you search spacer with some photos, part nos etc.
sonny
Post by sonny » Wed Aug 25, 2010 9:41 am
Welcome to the forum.
Virdee on here sells the H&R spacers which seem to the better make, Make sure there Hub-centric type. As above really depending on tyre width. If you are running STD 255s, then 10mm rear (20mm Axel width) and 8mm front (16mm Axel width) will be fine. some have gone 12mm (24mm Axel width) rear.
This will change the dynamics of the cars handling, and is recommended to get a 4WLA done due to the camber and trust changes.
PetrolDave
Post by PetrolDave » Wed Aug 25, 2010 11:47 am
MB2 wrote:10mm each axle at the rear seems to be the general concenus if you want to be able to put 275 tyres on.
You can fit 275 tyres without having to fit spacers, but if you want spacers I'd agree that 10mm seems the max to avoid 275's rubbing.
thedoluk
Post by thedoluk » Wed Aug 25, 2010 2:30 pm
How does the car handle with spacers on? Is it even better handling?
Daytona Avant - Optics - Titanium pack - MRC 464.6ps 513Nm - H&R ARBs + Springs - Apikol Diff mount - 034 Tranny mount - JHM Shifter
Brooner
Post by Brooner » Wed Aug 25, 2010 3:50 pm
Been told there purly cosmetic i asked was thinking of getting this done when at MRC
RS6chris!
Post by RS6chris! » Wed Aug 25, 2010 7:01 pm
Mine felt more planted...but i think it was more in my mind TBH....
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
lengster1
Post by lengster1 » Wed Aug 25, 2010 7:11 pm
10 mm hubcentric rears and 3mm plain fronts (any larger and wheel isnt properly located and 10 mm hubcentrics on the front were a bit ott for me)
sonny
Post by sonny » Wed Aug 25, 2010 7:27 pm
thedoluk wrote:How does the car handle with spacers on? Is it even better handling?
They will effect handling, In some cars for the better. I have not yet used the car with spacers on, I have a set to go on shortly (10r-8f).
However the more extreme spacers will cause more wear and tear on bearing and Axel components, so be advised. Max 10mm would be sufficient.
ginandjuice
Post by ginandjuice » Wed Aug 25, 2010 9:39 pm
thanks guys, i'm running 255's so 10mm rear 3mm up front sounds good.
