say the front of the car is set into oscillation...speed bump at high speed...
so you have a given mass moving...
if you have 2 shocks they will disappate the energy equally...
with only 1 damper it will do twice the work...
chances are it will do some amount 'more' because it won't be exactly proportional and the car will take longer to stop oscillating...
now consider side to side load transfer...one side dampened, the other not, the dampened side will do all the work to stop the car from moving...
less what is absorbed by the springs...where as if both sides had good dampers, each would contribute to stopping the motion
same thing applies to yaw movement in this case because of DRC
adsgreen wrote:But in itself damper doesn't carry any load? You could run completely undamped and load supported by the wheels under different conditions would be the same. Just the dynamics of the transient movement between two states would be completely different.
You could run one wheel without a damper and it' wouldn't affect the operation of the others. Yes, traction from the undamped wheel would be awful and the ride a bit... bouncy.. but I'm not sure it would cause the others to wear/fail that much quicker. I know this could be a little simplistic esp with the DRC the way it is and not trolling or trying to start an argument - genuinely interested.
Also, as an aside, as RS4's start to move to the end of the extended Audi DRC warranty I think I would look at conventional coilovers should they go wrong past the date. Has anybody done this before and does it ruin or impriove the car?
