SD card help ?
SD card help ?
Hi Chaps
I have just purchased a San Disk SDHC Card to transfer some itunes songs from my macbook onto. I transferred just 10 songs over and slotted it in to the SD card slot. The display just read, "reading card" for ages ?
I tried some mp3 tracks that I loaded onto the sd card and they didn't load. The itunes tracks are m4a ?
Can anyone help, I am not very familiar with this ?
James
James
RE: SD card help ?
SDHC (ie. high capacity) DO NOT work with the RNSE unit in the RS 4
you need just a normal SD card, which can be found in a rare 4GB form
- wellzieRS4
RE: SD card help ?
I got some 4gb sd cards on ebay the standard type not sdhc. 4 gb is the biggest card you can get that will work
Kaiser1976
Re: RE: SD card help ?
i thought you could only use 2x 2gb sd cards (thats what the handbook says)wellzieRS4 wrote:I got some 4gb sd cards on ebay the standard type not sdhc. 4 gb is the biggest card you can get that will work
Or 2 x 4gb (which is better).eightfoot wrote:i thought you could only use 2x 2gb sd cards (thats what the handbook says)wellzieRS4 wrote:I got some 4gb sd cards on ebay the standard type not sdhc. 4 gb is the biggest card you can get that will work
RE: Re: RE: SD card help ?
please all feel free to correct me if i am wrong, but i was under the impression that 4gb was the "total" capacity. I think you might need to have 2 x 2gb for it to work.
- PetrolDave
I'm amazed how often I have to post this information.
The pre-2010 RNS-E (which is what the RS4 is fitted with) will only work with SD cards (not SDHC cards), which are available up to 4GB maximum. It will work with 2 x 4GB SD cards.
The "fly in the ointment" is that 4GB cards are available as both SD and SDHC cards, but most (not all) are now SDHC. So when you're looking for a 4GB SD card you have to be very careful, especially as some SDHC cards are only marked SD.
The pre-2010 RNS-E is limited to 512 files per SD card, where file includes folders, MP3 files and M3U playlists. So unless you use 320kbps rip rate you'll probably reach that limit before you reach the capacity of a 4GB SD card.
Re: RE: Re: RE: SD card help ?
I agree, I have suggested before that this should be a sticky.PetrolDave wrote:I'm amazed how often I have to post this information.
- PetrolDave
+1Sims wrote:I agree, I have suggested before that this should be a sticky.
Any moderator willing to step forward and do the honours?
no, you can have x2 4GB cards in at the same time...iv done it
Users browsing this forum: 666Lenine and 205 guests
