BM Town Front LED units for B7?
seventeenAPG
Post by seventeenAPG » Thu Aug 05, 2010 9:05 am
P_G wrote:Will they have a built in resistor or is it an in parallel i.e. dangling on a wire resistor?
I'm hoping they have a built in resistor. If not I cant use them. Needs to be a direct replacememnt with no add ons for both sets of lights. Will let everyone know when the guinea pig gets them!!!
P_G
Post by P_G » Thu Aug 05, 2010 9:20 am
Good luck, the concern is if it does have a built in resistor it will have to be compact and will get mighty hot! Perhaps enough to melt the bulb socket?
tartan_rob
Post by tartan_rob » Thu Aug 05, 2010 9:54 am
IMO the LED's are not suitable for the RS4. The LEDs are from a newer generation of car.
Just my opinion though....
2017 Kawasaki Z1000
2014 RS6
2014 S1
MB2
Post by MB2 » Thu Aug 05, 2010 11:03 am
Tartan_Rob wrote:IMO the LED's are not suitable for the RS4. The LEDs are from a newer generation of car.
I think he is just replacing the DRL bulb with an LED variant rather than adding a "chain" of LEDs like the later Audis have.
seventeenAPG
Post by seventeenAPG » Fri Aug 06, 2010 10:12 pm
yes, just the bulb for a whiter and stronger light. Def would not go for LED strips. Wud make a real plaster of a nicel looking and agressive front !!!
seventeenAPG
Post by seventeenAPG » Fri Aug 06, 2010 10:14 pm
P_G wrote:Good luck, the concern is if it does have a built in resistor it will have to be compact and will get mighty hot! Perhaps enough to melt the bulb socket?
Will be careful, thx for the tip :lol: They had better not run hot to that extent, they should not be allowed to market if that's the case.
thedoluk
Post by thedoluk » Sun Aug 08, 2010 9:27 pm
has anyone tried the ones from ecstuning made by ziza I think
seventeenAPG
Post by seventeenAPG » Sun Aug 29, 2010 10:47 am
Guys, Got the LED bulbs and fitted them yesterday. They fit well and work great giving a much brighter whiter light as you can imagine BUT they activate the "bulb out" warning. States "headlight buld out". Pity :( Now removed and looking again.
Brooner
Post by Brooner » Sun Aug 29, 2010 11:31 am
Here's the way i went very happy with the result and don't look after market with the light off no light out warnning problem either
http://www.rs246.com/index.php?name=PNp ... light=drls
seventeenAPG
Post by seventeenAPG » Wed Sep 01, 2010 12:50 pm
Brooner wrote:Here's the way i went very happy with the result and don't look after market with the light off no light out warnning problem either
This place does not sell them any longer. Went on to the PIAA website and found these. Are they the correct ones?
S25 Bulb
27W Single Filament Bayonet
Mirror White incandescent bulbs
Crisp clean white light
P_G
Post by P_G » Wed Sep 01, 2010 1:46 pm
They are the ones.
Brooner
Post by Brooner » Wed Sep 01, 2010 2:12 pm
Yep that's them
seventeenAPG
Post by seventeenAPG » Wed Sep 01, 2010 2:14 pm
Brooner wrote:Yep that's them
MAny thanks; just ordered them. Mind you it says there are for show use and not road use!!
seventeenAPG
Post by seventeenAPG » Sun Sep 05, 2010 11:08 am
Thank guys. Just noticed today that they do not mention the word "chrome" . I saw yours fitted and they look great. They have a chrome tip which blends in well. Do you know if your packaging actually mentioned th eword"chrome"? Those in the pic I took look blue in colour which I would def not want.
Thanks...
Brooner
Post by Brooner » Sun Sep 05, 2010 11:27 am
the picture is corrcet as for the wording most of it's in Japanees but miiror white is the correct bulb had mine fitted for almoost a year mow with no issues
Users browsing this forum: No registered users and 377 guests
