blue connector plug?
2.7 V6 30v biturbo - 380 bhp
missmouse
Post by missmouse » Wed Jul 28, 2010 7:18 pm
anyone know where this blue connector is meant to go? Its at the rear of the engine, has two terminals & its cable is about 8" long comes out of the engine loom at the rear centre.
Its not the aux water pump (black) or the temp sender & the car runs fine! Also no fault codes showing on Vagcom!
Any ideas? Anyone ever had their engine out & unplugged all the plugs?
stunew
RE: blue connector plug?
Post by stunew » Thu Jul 29, 2010 2:17 pm
It could be a spare unused one, have seen that before amny times. Suspect if car running fine and no fault codes then that is what it is.
If I have time at the weekend I will have a look at mine to see if I can see the same blue plug.
missmouse
Re: RE: blue connector plug?
Post by missmouse » Thu Jul 29, 2010 5:27 pm
stunew wrote:It could be a spare unused one, have seen that before amny times. Suspect if car running fine and no fault codes then that is what it is.
That would be great if you can! Thanks,
simon
