Milltek pricing
Update II:
I have found a supplier who will supply at the following prices if the order is for 3 or more exhausts:
Non res, valved, silver tipped £1,340.10
Non res, valved, black tipped £1,684.80
I can get other prices for cats, resonated or non valved etc as required.
Waiting on the other suppliers to reply.
I'll be having one at that price, so I need two more orders. Not sure on the logistics of getting the orders, I assume if we all ring the supplier with our order quoting my name we can get the discount and he'll deliver to each person once he's got 3 payments.
Open to other suggestions on how to work it.
THE FOLLOWING PARTS ARE INCLUDED
(MSAU306) TWIN LINK PIPE ASSEMBLY
(MSAU307REP) LH NON RESONATED CENTRE SECTION
(MSAU308REP) RH NON RESONATED CENTRE SECTION
(MSAU317) LH REAR SECTION INC EXHAUST VALVE
(MSAU314) BRACE BAR
(MSAU318) RH REAR SECTION INC EXHAUST VALVE
Pipe Diameter: 60.00mm (2.36")
Tailpipe: Special
(Non-resonated. Including Exhaust Valves. Polished Oval Trims)
(MSAU314) BRACE BAR
Tailpipe: Special
Be wary of getting prices for cats....ShouldveBeenAGerman wrote:I can get other prices for cats, resonated or non valved etc as required.
http://www.rs246.com/index.php?name=PNp ... 879#394879
count me in fella - im after as said before, valved non res black tipped.
pm me or post where to phone and who to speak to.
many thanks for taking the time to sort something out.
regarding the cats - ive read the posts, but think youd be mighty unlucky to get fined.
ive changed cats on several cars over the years - the last in january on a mazda 3mps. never had any hasstle form the garage who put it on or the place that later did an mot. wouldnt stop me changing a cat on any car - they have to prove when it was done in the first place which might be a tad tricky - unless theyre going to trace serial numbers?
Just to let you all know .. There are non in stock at the factory ..
Unit 20
0151 3366888
0151 3366888
That's not strictly true, if your car is regsitered post 2001 and has non type approved cats on it, it apparently doesn't matter when the cats were replaced you would be investigated. You would have to prove (not them) they were replaced before August 2009 before the legislation took place otherwise you are asked to replace them and if not a fine of £5,000 per cat.stoddie wrote: wouldnt stop me changing a cat on any car - they have to prove when it was done in the first place which might be a tad tricky - unless theyre going to trace serial numbers?
You may be unlucky but I don't have £10K to pay up to take the risk. And garages who supply and fit are also under scrutiny.
- wellzieRS4
Re: RE: Milltek pricing
[quote="Stevieb03"]I would be interested in a Cat-Back, non Res, INC valves, with Satin Black tips, plus the down pipes with 200 cell CATs...
Me too
Me too
Thats the set up I have (bar the black tips) and I must say I am very impressed with the sound esp combine with a BMC panel filter. There is a clip on here of me doing a few laps at Brands, dig that up, should be able to give you an idea of the noise.wellzieRS4 wrote:Stevieb03 wrote:I would be interested in a Cat-Back, non Res, INC valves, with Satin Black tips, plus the down pipes with 200 cell CATs...
Me too
RE: Re: RE: Milltek pricing
Would you let a little old S4 onto the buy? If so where is the supplier located because would like fitting too
Users browsing this forum: No registered users and 90 guests
