Do Regular porsche Cup 1 alloys fit the RS ?
2.2 I5 20v turbo - 315 bhp
MusicMadMike
Post by MusicMadMike » Fri Jul 16, 2010 1:18 pm
Sorry guys if I rehashing an old topic, but I did have a good dif around honest! A pair of Porsche Cup 1 alloys has popped up on EBAY. What I need to know is will they fit on the RS2 with no modification? I thinking about getting a second set for winter tyres of for some track day action if I'm feeling brave.
http://cgi.ebay.co.uk/Porsche-OEM-Cup1- ... 3caef6db91
cheers
MMM
Rob20vurq
RE: Do Regular porsche Cup 1 alloys fit the RS ?
Post by Rob20vurq » Fri Jul 16, 2010 7:25 pm
NO they don't. only thing stopping them fitting is the centre bore. Porsche is 71.6 RS2 is 73.1
Just take them to a machine shop and get them to turn them out.
HTH
Rob20vurq
Post by Rob20vurq » Fri Jul 16, 2010 7:26 pm
those have the wrong off set too!
MusicMadMike
Post by MusicMadMike » Mon Jul 19, 2010 4:55 pm
Thanks for that. What should the offset be. I must admit to being a bit confused by this stuff :|
Rob20vurq
Post by Rob20vurq » Wed Jul 21, 2010 8:39 am
The 7" standard wheel has a 55 off set if you went higher say 60 the wheel moves inwards.
You have to take into account wheel width. If you went to 8" wide the extra 1" is added to both sides of the center line.
The 964 did come with 8" wide et52. They fit spot on after the middle has been turned out. You can then run the 245 40 17.
HTH
MusicMadMike
Post by MusicMadMike » Thu Jul 22, 2010 4:17 pm
Right I will see if I can hunt down a set of those. I take it that extra width doesn't hit the arches (just had them rubbed down, treated and resprayed to get rid of some rot) or the inner wings.
Thanks for the help
MMM
