Intake problem
2.7 V6 30v biturbo - 380 bhp
Sql_RS4
Intake problem
Post by Sql_RS4 » Sat Jul 10, 2010 3:14 pm
Just got back from 1/4 mile event here in Poland.
Decided to have a go just to see how my last 60 hp gain looks time-wise...
And got nicely dissapointed.
Stage 2, 280 hp DSG Scirocco 2.0t gave me a hard time!
Every gear above 5k rpm lacked boost, totally! Everything was perfect till 5k and then just nothing, gear up, ok till 5 k rpm then nothing again.
:shock: :shock: :shock:
Hood up and this is what happened:
First thought - clogged air filter, but it was replaced 3 months ago, checked - OK.
What do you think could have caused this? Any experiences?
Maybe just a 10 year old rubber part that didn't like 35-38C outside temp combined with temp under the hood?
You think I should replace it with OEM or maybe there is something else available from Samco and the like?
Thanks in advance!
lengster1
RE: Intake problem
Post by lengster1 » Sat Jul 10, 2010 3:25 pm
Is it possible the engine has rocked alot under hard acceleration and the pipe has hit the bulkead and caused the damage?? Worn/tired engine mounts could cause this maybe?
Sql_RS4
RE: Intake problem
Post by Sql_RS4 » Sat Jul 10, 2010 3:27 pm
I was thinking the same but I have custom race engine mounts so I do not think there is a chance it could be the problem.
jimbo1234567
RE: Intake problem
Post by jimbo1234567 » Sat Jul 10, 2010 5:35 pm
the heat causes the plastic to go soft when you are waiting in a que, get a less restrictive air filter and like i said a silicone coupler.
Users browsing this forum: Google Adsense [Bot] and 62 guests
