WTD - Spacers
WTD - Spacers
2x 10mm hubcentrics for a B5 RS4 please...
B5 RS4 - now sold.
B5 RS4 - now sold.
RE: WTD - Spacers
Bump
One needed as a minimum...
B5 RS4 - now sold.
B5 RS4 - now sold.
RE: WTD - Spacers
Think I've got some in the garage mate. If I can find them in amongst the mountain of crap you can have them if you cover postage
RE: WTD - Spacers
May need spigot rings but can't remember as I've only ever used them to work out dimensions for some custom made pcd adaptors on my last car
RE: WTD - Spacers
Thanks, but needing hubcentric to be bolted on...
Cheers anyway.
Cheers anyway.
B5 RS4 - now sold.
B5 RS4 - now sold.
RE: WTD - Spacers
Ones that bolt to the hub, then the wheel bolts into the spacer?
RE: WTD - Spacers
The spacer sits over the hub, then the wheel bolt slides into and through the spacer and tightens up - so needing longer bolts to pass through the spacer
The Spacers have holes drilled out to match the car's hub hole locations?
B5 RS4 - now sold.
B5 RS4 - now sold.
