Hopefully the weather will be ok tomorrow so I can get it fitted. Also got all new O-rings and pintle caps for the injectors to make sure its all spot on when reinstalled.
Oh yeslee_whitehead wrote:oooo, keep us posted, although, will you see much difference before a map?
No, i didnt bother. The manifold is still hot, but now you can hold your hand on it for a while, rather than before which it was almost too hot to touch, if id thought of it I wouldve used my mate laser thermometer before and after to see the actual figures. But the spacers will increase the inlet runners length anyway sotheyll still add torque and they are tapered and port matched to the inlet and head so thatll help aswellinfrasilver wrote:Looks good. Keep us posted on how your mods affect the power output.
Have you gone for the heater bypass mod too to keep the intake even cooler or is that just a US mod?
Edited due to iPhones being crap to type on and predictive text being too auto edit happyxyber wrote:Oh yeslee_whitehead wrote:oooo, keep us posted, although, will you see much difference before a map?![]()
Went out, got a fresh tank of VPower and went for a play. Considering it is just a standard manifold, with some clever smoothing and trickery on the inside, I wasn't expecting these results!!
There was a TSB about that (24.04.02). Even if my car was not supposed to be impacted by the issue I did notice the same thing one or two years ago: a bolt was completely out. Since I got used to recheck them during each service and recently I swapped for new ones stronger (higher resistance alloy) to see if it cures the issue.xyber wrote: I noticed when removing the manifold that the bolts had hardly any tension on them at all so they may have backed up on their own, so may be worth people checking them just incase. They are the 14, 5mm allen bolts on the outer most parts of the manifold. NOT THE TORX/STAR BOLTS
Monitor you start up rattle if you have it. See if with the manifold tightened down it's improvedinfrasilver wrote:I have checked my inlet allen head bolts today after reading this and found that 4 of the 14 were slightly loose. I was able to get a quarter of turn from the 4 loose bolts. Worth keeping an eye on.
Users browsing this forum: No registered users and 39 guests
