any has done this on the rs6?
put a nice dual 76mm set on the car? is it worth it? what would it sound like?
as i dont want my car sound like a v8 lumina
thanks
is that a miltek system? how much will that cost? and what sort of power gains would you expect from decatting, is there any negative effects? what powergains will it give?bam_bam wrote:Think NASCAR with the volume turned down to 10... from 11.
I've set money aside for 3" CAT-less downs next month.
hmm i wander how i could get around the misses with this one!? i used to know a chap who made custom exhausts he was very good based in staffordbam_bam wrote:I'll let you know after the installation, there is other work to be done that will also require a remap. It's ok, I'll feed the backs.
Maybe, maybe not.Gravitypilot wrote:wont you need the cats for emissions?
yes i saw on their website... if i remember rightly to work with 3 inch properly you need some good equipment as some of the smaller custom exhaust places use a crushing method to make the bends and it narrows the bore even more so on the bends.. i cant remember what the other method is called but i bet 3 inch complicated pipe work will not be cheap..bam_bam wrote:Maybe, maybe not.Gravitypilot wrote:wont you need the cats for emissions?
I got a few quotes for a custom exhaust... not cheap and it'd have to be an engine out job to be done correctly (so I'm told). I've just checked my quotes for what I want to get done next month, it says "Milltek will do us a nocat downpipe.." - that doesn't tell me it will be 3" as everything Milltek list for the C5 RS is (only!!) 2.75". Still, it'll be interesting.
Users browsing this forum: Google [Bot] and 154 guests
