Brake Discs
Brake Discs
Is it true that you can only get standard discs for the RS6? Spoke to someone at Venom Motorsports today and they claimed no one manufactures discs other than Audi.....
RE: Brake Discs
True it is! Although if you wanna go bigger then there are a couple of kits out there.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
275 Vreds.
Miltek Resonated.
Hi Flow filters.
RE: Brake Discs
YOu can put Phaeton disks on the rear with some slight mods. DK did it.
Cornishmoocher
- Top Gear
RE: Brake Discs
Actually Eddie ( and we don't disagree on much if anything) Movit do a brake kit for the RS6, but they are eleventy billion quid.
It's all Bollox.
RE: Brake Discs
Mov'it do big brake kits both front and rear. Stoptec callipers will fit on the rear (sans hand brake function). According to Grizz, the C6 rear disc can be fettled to fit on the C5 rear. I think Sportec do C5 RS brakes too but they're 380mm and probably 8 pots, no doubt cost the earth.
I've got C6 RS 390 front discs and 6 pot callipers fitted to the front of my C5 RS. Now they're broken-in they are truly bonkers, they'll break your neck and slam your head in your lap.
Cornishmoocher
- Top Gear
RE: Brake Discs
They are quite good aint they?
It's all Bollox.
RE: Brake Discs
I was stomping on them relentlessly and I'd hazard a guess my frail and meek DRC couldn't handle the punishment those huge brakes were dishing out.
Re: RE: Brake Discs
I did say there were kits out there. .............Cornishmoocher wrote:Actually Eddie ( and we don't disagree on much if anything) Movit do a brake kit for the RS6, but they are eleventy billion quid.
'True it is! Although if you wanna go bigger then there are a couple of kits out there.'
So we definately dont disagree on anything then.
Now Sold!
275 Vreds.
Miltek Resonated.
Hi Flow filters.
275 Vreds.
Miltek Resonated.
Hi Flow filters.
Cornishmoocher
- Top Gear
RE: Re: RE: Brake Discs
I really should learn to read......... That went in one eye and out the other!
It's all Bollox.
IIRC - I think he meant Mov'it do an OEM spec fit. Meaning Audi aren't the only ones to make discs for the C5 RS. Although, I could be wrong.... Yup, I was. I'll get me coat.
Mov'it do a 370x35 disc for the C5 RS, not sure if that's a straight fit though. The OEM is 365x33.
Got standard discs on the way. Cheers chaps.
Re: Brake Discs
Sorry to resurrect this thread but couldnt justify starting another.
Whats the height of the front C5 disc?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Re: RE: Re: RE: Brake Discs
This.
bam_bam wrote:Mov'it do a 370x35 disc for the C5 RS, not sure if that's a straight fit though. The OEM is 365x33.
Re: Brake Discs
Yep that's interesting too.
Back to the other thing, if the disc is lying flat on the ground, what is it's height, as opposed to diameter and thickness?
