Spacers?
Spacers?
I,m currently running 10mm rears and 8mm fronts....anyone running 15mm rears and 10mm fronts on here?
Would 15mm rears be too much? and do 10mm fronts work?
I have standard suspension?
Chrissy.
Chrissy.
RE: Spacers?
Porky is running 12mm on the rear. If your car is not lowered I would say it would be ok. You might get a bit of rubbing on full lock.
Bet it would look phat with 15mm's
RE: Spacers?
im running 10mm rear and nothing up front...
try that, might give you the stance your after...
Re: RE: Spacers?
Pics? would like to see the stance, take it from about 3 meters back so it shows the wheels protruding out side the rear endjonathonturner wrote:im running 10mm rear and nothing up front...
Re: RE: Spacers?
RE: Re: RE: Spacers?
wheels dont prutrude..they just sit flush..they are 10mm each side...?
OK i still have my spacers to put on yet, still not got around to it. 10r/8f
i persoanlly thing the front wheels sit fine in the arch, and given they steer as well,i thoguht best to leave that end alone,,
so i went down the rear only, and am well happy.
i havent got any snaps of my avant, but here's my previous saloon, very dirty with just rears.
I run 10mm hubcentric rears and plain 3mm fronts
Re: RE: Re: RE: Spacers?
It sits just right. I will have to get mine fitted, hopefully wont have any problems with my 20mm dropjonathonturner wrote:i persoanlly thing the front wheels sit fine in the arch, and given they steer as well,i thoguht best to leave that end alone,,
RE: Re: RE: Re: RE: Spacers?
any more pics with spacers??
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
10mm rears should be fine...whack em on..takes five mins..you'll wonder why you didnt do it before..sonny wrote:It sits just right. I will have to get mine fitted, hopefully wont have any problems with my 20mm dropjonathonturner wrote:i persoanlly thing the front wheels sit fine in the arch, and given they steer as well,i thoguht best to leave that end alone,,
Hi - I have a question, When you talk about 10mm on the back and 8mm on the front is that per wheel or overall?
I'm currently looking at Eibach Pro spacers, could anybody tell me if they are any good and that they are hubcentric?
Thanks all
Thanks all
That is per wheel, so 20mm axle width and 16mm axle length.
I have seen the Eibach spacers split before on a BMW, not good. H&R get the thumbs up from here. If it has a lip on the hub area then it is hub-centric, this is what you want.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 226 guests
