Request for gents with a data logger:
ArthurPE
Post by ArthurPE » Wed May 12, 2010 5:31 pm
allow me to elaborate:
do I believe:
air filter (K&N?) tests I've read, 4-5 HP
ported manifold
low restriction cats
low restriction exhaust
and matched software (more agressive timing, rev limit increasd?)
can yeild 6% or 25 HP, 415 to 440? and nice mid-range torque...
YES, as would be confirmed by the 3k to 8k times, 7.5 vs 8.5
I'm guessing ~$7k for the work, and for those so inclined, seems like decent value...
when younger I had the 'bug', and wanted a bit faster, a bit better than the 'other guy', that's cool, and human nature...to each their own, good for them...
do I believe:
cleaning the valves make >9% more HP, 370 to 404 or 34 HP? NO, why?
airflow improves 1 to 2% at best, call ir 6 HP, same order of magnitude as the air filter (and I have shown why this makes sense)
it does not impact timing...
so cleaning the valves yeilds more 50% more power than all the above mods?
it doesn't wash...it doesn't pass the 'sniff test'
Sims
Post by Sims » Wed May 12, 2010 5:53 pm
ArthurPE wrote:...
..so cleaning the valves yeilds more 50% more power than all the above mods?[/b]
What if the valves were really, really badly clogged up?
Do we have pics before the clean up?
ArthurPE
Post by ArthurPE » Wed May 12, 2010 5:59 pm
Sims wrote:
ArthurPE wrote:...
the valves can never clog up enough to impede Q more than 2%
the deposits are self limiting
in additon the torus caused by the valve lift (which is the area) the deposits would restrict, is by far the least significant part of the pressure drop system, starting with the airfilter, TB, etc., all the way into the cylinder...
not possible
25 HP (many, many mods) 34 HP, cleaning the valves...
nope, not in my professional opinion
but everyone is entitled to one...
Sims
Post by Sims » Wed May 12, 2010 6:08 pm
ArthurPE wrote:
not possible
It will be good to hear Billy's opinion.
P_G
Post by P_G » Mon May 17, 2010 10:14 am
Back on track; Arthur you may want to add the following data;
2006 Audi RS4 Avant
65,000 miles
14 degrees C outside temperature
Full tank of Tesco 99 RON
135 kgs on board weight
TC on
3k-8k rpm (100% throttle at 3k rpm only)
4 runs
8.7
8.9
8.7
8.8
ArthurPE
Post by ArthurPE » Mon May 17, 2010 2:32 pm
P_G wrote:Back on track; Arthur you may want to add the following data;
2006 Audi RS4 Avant
65,000 miles
TC on
4 runs
8.7
8.9
8.7
8.8
wow, that's good considering
135 kg (driver & passenger or some extra load?)
full tank of fuel...
extra wt of an avant...
try 100% throttle at 2500, so you are 'rolling' by 3000
if your'e down 80-100 HP I would expect > 10 sec
even 20 should put you >9.3 sec with that much wt
P_G
Post by P_G » Mon May 17, 2010 4:44 pm
135 kgs was driver, passengers + shopping!
I would normally try 100% ta 2500 rpm but because it is off a roundabout on to a dual carriageway with other traffic nearby if I start slower I get overtaken and can't do the run!
ArthurPE
Post by ArthurPE » Mon May 17, 2010 9:02 pm
P_G wrote:135 kgs was driver, passengers + shopping!
2 recent runs in the US:
driver only
<1/2 tank fuel
100% at 2500
cleaned cars
sedans
1) 95 octane/ecu/exhuast ~8.6+, corrected 8.4
2) exhaust/forged wheels/tuned up ~8.7, corrected 8.6
considering yours:
fuel, load plus avant >250 lbs heavier
100% at 3000
uncleaned
and yet within a few 10'ths
no extra wt & 100% at 2500 you're <8.5....easily
NO one is going to convince me your car is not making rated power or that deposits cost 20-100 HP...
zorbs
Post by zorbs » Mon May 17, 2010 10:51 pm
I've just come back from doing some runs post the MRC work I had done (completely oem exhaust though):
7.7 (realised halfway through I wasn't on full throttle)
7.5
7.5
7.5
Tesco 99 (I think), about 1/4 tank, 11 degrees outside, dead flat road, engine oil around 95 degrees.
RS4 (06) saloon, phantom, satnav+, adaptive lights.
Audi TT MkII Coupe 2.0 TFSI
E36 BMW 328i Coupe (great car)
scaghead
Post by scaghead » Mon May 17, 2010 10:56 pm
good times fella, dougie is a good guy, had my motor serviced by them and would not go any were else now
ArthurPE
Post by ArthurPE » Mon May 17, 2010 10:57 pm
zorbs wrote:I've just come back from doing some runs post the MRC work I had done (completely oem exhaust though):
7.5
7.5
7.5
good runs, what are your mods?
corrected ~ 7.9 (temp and load)
I adjust to 77 F (SAE std) and 1/2 tank of fuel...
I would guess ~15 to 20 HP more than stock (assuming 415 stock)
so 430+...
Sims
Post by Sims » Mon May 17, 2010 11:04 pm
ArthurPE wrote:[
It's all on here.
http://www.rs246.com/index.php?name=PNp ... ic&t=84085
sonny
Post by sonny » Mon May 17, 2010 11:55 pm
7.5
7.5
7.5
Nice times there.
zorbs
Post by zorbs » Tue May 18, 2010 2:28 am
7.5
7.5
7.5
Nice times there.
Says the man with the nuclear powered RS4 :lol:
ps. We should meet for a lunchtime Guiness again soon.
sonny
Post by sonny » Tue May 18, 2010 6:50 am
yes that sounds good, a Guiness and chat over carbon deposits, mans talk LOooooOL
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 226 guests
