Thank you, but alas no...mac4RS wrote: And most of the 'smoke' comes from you...![]()
Да, Ñmac4RS wrote: Hey Sims, you a mate of russianM3dude?
How about you tell usArthurPE wrote:I have over 60 cars and 200+ runs now, that was very early in the experiement, also it doesn't have the temp/wt compensation applied
whether you believe the data or not has no relevancy, it is an accurate representation of what is going on...
and as far as deposits, no power loss
all data will have flyer, and in this case anything below 8 sec needs a hard look, just as >9 would
since a car using all gears only runs only 8 flat...
how much power would it take to go from 8.5 to 8 sec?
Sims wrote:How about you tell usArthurPE wrote:I have over 60 cars and 200+ runs now, that was very early in the experiement, also it doesn't have the temp/wt compensation applied
how much power would it take to go from 8.5 to 8 sec?together with all the likely scenarios from 7 to 7.5, to 8, to 8.5 and 9.0 and 9.5. It's your baby.
And a sample of with all the variable is simply not credible.
Come fella, you can do better than thatArthurPE wrote:Sims wrote:How about you tell usArthurPE wrote:I have over 60 cars and 200+ runs now, that was very early in the experiement, also it doesn't have the temp/wt compensation applied
it is statistically valid, Audi found it interesting...Sims wrote:
Come fella, you can do better than thatLet's really home in on this data so we can all decide whether it's worth partaking in, or that it has no universal value (perhaps, a big perhaps, limited value on an individual basis as P-G suggested).
[/quote]I have something better than thatSR71 wrote:Someone do us a favour and run some of the individual car data through http://www.cartestsoftware.com/index.php
I used to muck around with this software when it was free back in the 90's...
You can alter almost everything you could possibly want to along with sensitivity analyses etc etc
it is representative of the cars relative and absolute speed...
no difference, cleaned uncleaned
I'm not wasting time on you...it is pointless
do your own work
Here is the link:P_G wrote:You'll have to refresh my memory ....
P_G wrote:What I wrote in response to your times Sims?;
"Are you a saloon, Avant or cab? Avant
How much fuel did you have on board at the time?25 litres
Was it just you or did you have passenger / extra weight on board? 2 people combined weight 120kg
Are you using 95, 98 or 99 RON fuel? 99 Shell
What was the external temperature? 5 degrees
Did you have the accelerator flat to the floor before you hit 3000rpm or hit 3k rpm then nailed it? hit 3k and then nailed it, oops, did I do wrong?
Best to nail the pedal to the carpet at 2k rpm and then start timer at 3k rpm through to 8k; I originally did the same and then the proposed method and it can take up to 0.3 second off. Minus the weight of an additional passenger, who knows. Also, how many miles have you got on the clock and how old? and did you have TC'off'?
Put it this way, mine (Avant) is consistently doing 8.2 to 8.1 with 61k miles on the clock and just me in the car and I am big boned. If you are getting around that time up to 8.4/8.5 it is in fine health."
Users browsing this forum: Google Adsense [Bot] and 170 guests
