Possible flywheel problem?
BBJ
Post by BBJ » Thu May 06, 2010 7:03 pm
Hi guys,
long time lurker, 1st time poster here.
Unfortunately my B6 has developed a deep rumble/vibration throughout the rev range. Performance seems unaffected though. Having read through some threads it sounds a bit like a Dual Mass Flywheel problem, do these symptoms sound about right?
If it does turn out to be the DMF i've found a company that sells a Single Mass version for £260 here http://www.delta-performance.com/dvg-au ... -p-82.html. Would it be a better idea to fit one of these rather than have another DMF fail in the future. (I love the car and don't see myself selling it any time soon)
John
xyber
RE: Possible flywheel problem?
Post by xyber » Thu May 06, 2010 7:42 pm
Sounds like it may be the FW separating.
You'd want to keep the DMass one to minimise the shock transmitted through it
JHMotorsport do an RS4 clutch and FW kit that's highly rated that quite fancy
1781cc
Post by 1781cc » Thu May 06, 2010 10:08 pm
dual mass from Mr Clutch, cheapest I found fitted and includes a clutch kit!
grizz
Post by grizz » Sat May 08, 2010 10:22 am
Make sure it's a oe quality flywheel .. You buy cheap you buy twice ..
Unit 20
0151 3366888
BBJ
Post by BBJ » Sat May 08, 2010 6:48 pm
Strangely enough the noise has since disappeared, car now runs and sounds fine. :? Oh well, big repair bill avoided!
xyber
Post by xyber » Sat May 08, 2010 7:50 pm
Electrical connection loose or faulty to an engine mount. Should show up on a scan
Moosey
Post by Moosey » Mon May 17, 2010 10:12 am
B6s don't have a dual mass flywheel.
BBJ
Post by BBJ » Mon May 17, 2010 10:09 pm
Is that definate?
Also, forgive my ignorance but why does an engine mount need electrical connections?
xyber
Post by xyber » Mon May 17, 2010 10:18 pm
I'm sure they are dual mass
the engine mounts are hydraulic and have a solenoid, when on throttle they stiffen up
