Hi,
Bought my RS4 in November and since then I have done 2500miles and have had to top up the coolant 3times where its just been showing below the minimum mark.
I cant find any leaks and the undertray is squeeky clean, it still under warranty but was going to get it sniff tested and pressure tested to see if I have a serious issue.
Has any else had problems with coolant?
Thanks in advance,
Tom
Coolant level keeps dropping...........
Re: Coolant level keeps dropping...........
Hi, same here. Check both small radiators. Mine is KO on drivers side (left side driving). Hope that water isnt "eaten" by engine.
Good luck
BR
Garry
Good luck
BR
Garry
tom2009uk wrote:Hi,
Thanks in advance,
Tom
- PetrolDave
+1cz.Garry wrote:Check both small radiators.
A known weakness on the B6 and the B7 is the auxiliary radiators.
I had to have the offside auxiliary radiator replaced last year. No sign of stone damage, just corrosion due to water being trapped against it.
RE: Re: Coolant level keeps dropping...........
Thanks for both of your fast responses! I will get the undertray back off this week and get looking, how likely is it that this would be covered by Audis used car warranty?
Thanks,
Tom
Thanks,
Tom
If you have the pink coolant, this stuff dries, and the crystals are easy to spot. I would get it u on a ramp and get it inspected. as above the Aux rds are a weak point. Also the alternator is water cooled, check this too. the alternator might be the problem.
Users browsing this forum: Google Adsense [Bot] and 94 guests
