Mobil 1 5w-30 VW 504/507 £8.50 for 1L ;-)
RS04OUR
Post by RS04OUR » Fri Apr 16, 2010 2:34 pm
I went to my local Audi dealer to buy some Mobil 1 5w-30 VW 504/507 oil, the cost being £19 for 1L at the moment to find they had non left.
I remember someone on here saying that Asda had an offer on this oil so I went there, and to my joy it's only £8.50 for 1L or £32 for 5Ltrs!
Thanks for the tip ;-)
RS4 Sprint blue 100% Audi - Gone but will never be forgotten.
S3 Stronic on order coz I'm old ;-)
skywriter
Post by skywriter » Fri Apr 16, 2010 2:49 pm
or £42.50 for 5
RS04OUR
Post by RS04OUR » Fri Apr 16, 2010 2:51 pm
or £85 for 10 (?)
Teutonic_Tamer
Post by Teutonic_Tamer » Fri Apr 16, 2010 4:44 pm
That Mobil 1 is cheap for a reason - it is not as good as say Castrol Edge or Fuchs Titan GT1
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
RS04OUR
Post by RS04OUR » Fri Apr 16, 2010 5:24 pm
Well, you live and learn - Audi tried to sell the VAG own Quantum stuff, which is best of those two IYHO please?
P_G
Post by P_G » Fri Apr 16, 2010 5:47 pm
Quantum is quoted as being blended in the same place as Castrol for VAG using the same techniques. So theoretically the same.
Teutonic_Tamer
Post by Teutonic_Tamer » Fri Apr 16, 2010 8:41 pm
RS04OUR wrote:Well, you live and learn - Audi tried to sell the VAG own Quantum stuff, which is best of those two IYHO please?
The Quantum stuff is a special deal between Castrol and Volkswagen Group UK. Unfortunately, whilst the Quantum stuff is VW approved, it isn't 'Volkswagen Germany' approved for franchised workshop use. Official franchised workshops should ONLY use oil from a 'premium' brand (which would include Castrol, BP, Fuchs, Motul, Elf, Total, and also Mobil). Quantum oils are only meant for the 'Independent Motor Trade'!
Teutonic_Tamer
Post by Teutonic_Tamer » Fri Apr 16, 2010 8:45 pm
P_G wrote:Quantum is quoted as being blended in the same place as Castrol for VAG using the same techniques. So theoretically the same.
Yes, Quantum is blended at the same 'UK Lubricants plc' plant in Belgium, which is where Castrol stuff is also blended. However, Quantum lubes are categorically NOT the same as Castrol lubes. Quantum are slightly inferior to the genuine equivalent Castrol brews (either the 'consumer' Castrol EDGE, or the 'professional workshop' Castrol SLX Professional Powerflow).
RS04OUR
Post by RS04OUR » Fri Apr 16, 2010 10:37 pm
So, what do you put in your car Sean?
P_G
Post by P_G » Fri Apr 16, 2010 11:39 pm
Not entirely true as my local franchised dealer uses Quantum in its workshops; so says the big 50L drums they have round the back of the workshop and the techs in it.
That and they have swapped between Castrol and Mobil-1 dependent on who has a supply deal on. My RS came with Castrol, AVS1 with Mobil 1, AVS2 on Castrol and since then I have changed out every 5k miles with Castrol but if I put it into the dealer who knows as both are in stock presently.
They say either works equally well and the even if you chnage to fixed service intervals still to use the same longlife 504 /507 spec. variant oil
lengster1
Post by lengster1 » Sat Apr 17, 2010 12:17 am
Main dealer put Quantum in my b5 which i wasnt too pleased at after only finding out afterwards. Ive watched these oil threads with interest as ive just put mobil1 esp in the b7 on an inbetween service as i feel 15k is too much on the same oil but maybe im wrong with these latest longlife oils?
ArthurPE
Post by ArthurPE » Sat Apr 17, 2010 12:21 am
imo, any approved oil is as good as the other...
I don't subscribe to 10k changes though, 5 to 6k is what I do
consider:
large volume, almost 10 l, better dilution
good filtration system
good cooling system
oil runs hot (burns moisture off) but not too hot, see good cooling system...
if it's the correct spec and approved, and changed at<6k, any brand will do fine...
P_G
Post by P_G » Sat Apr 17, 2010 12:23 am
Uhoh, I see a throw away comment about to ignite heated debate! :lol: :wink:
Angelo_Amato
Post by Angelo_Amato » Sat Apr 17, 2010 12:39 am
Interesting info on the quantum oils, I've used quantum oils for the last 10 years in my VW/Audi's but none as hi-po as the RS.
When i went to the dealer to get my first litre of top up, they gave me Shell Helix VX :?
I'm looking for a brand of oil to find and stick with as I normally do, my choice was the Mobil too as been around for ages and easily available, feel myself getting confused again! LOL
ArthurPE
Post by ArthurPE » Sat Apr 17, 2010 12:43 am
P_G wrote:Uhoh, I see a throw away comment about to ignite heated debate! :lol: :wink:
:sekret:
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 170 guests
