anyone had to have a new clutch?
2manytoys
RE: Re: RE: Re: clutch faulty
Post by 2manytoys » Fri Apr 16, 2010 11:03 am
When you say clutch pipe, do you know what that is exactly?
sonny
Post by sonny » Fri Apr 16, 2010 11:24 am
Clutch fluid return pipes, associated with the hydraulic system. when these split, you loose pressure and can not activate gears, you can NOT crash the gears either, only way is to turn engine off, select gear, start engine and move the car (only a very short distance). its more of a emergency procedure.
Another way to check if your leaking fluid, some f it may drip down onto the underside of the car or on your driveway, will appear to be like a oily wax.
2manytoys
Post by 2manytoys » Fri Apr 16, 2010 11:34 am
Great, thanks. I'll take it in next week and let you all know what Audi find.
Teutonic_Tamer
Post by Teutonic_Tamer » Fri Apr 16, 2010 9:03 pm
^Qwerty^ wrote:It does it radomly in stop/start traffic (i.e. driving in York on the way in/out of work in busy traffic) and also nearly on demand when you use full revs in 2nd, 3rd and 4th, then change back to 3rd. The pedal stays on the floor and I loose drive. There is then a bang as the clutch unjames itself and drive returns.
My last B6 S4 suffered with identical symptoms. The 'self adjusting' pressure plates basically start to brake up. All replaced under warranty, with a new flywheel too.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
^Qwerty^
Post by ^Qwerty^ » Sun Apr 18, 2010 8:50 am
Well, top marks to Audi, as I get my car back next week with *everything* to do with the clutch including the clutch itself, new. And whilst mine has been in the garage, they sent me a brand spanker long wheel base A8 to run about in.
klauster
Post by klauster » Sun Apr 18, 2010 12:16 pm
I'll get them to check over my cluth when its serviced in a couple of months
Users browsing this forum: Bing [Bot] and 77 guests
