Rear Wheel Camber
Steviescottish
Rear Wheel Camber
Hey guys.
Anybody know if it's possible to adjust the rear wheel camber on the B5 RS4?
She has a tendancy to wear the inside edge of the rear tyres prematurely.
I would appreciate any input.
Cheers.
Cheers.
RE: Rear Wheel Camber
I was looking into this myself! Is yours lowered? I have been trying to look into some adjustable rear tie bars?
jimbo1234567
- 5th Gear
camber is adjustable on the bottom outer bolt, toe is also adjustable on the rear of the subframe where the tie bar attatches to it, both work on an elongated slot with a washer that has an offset hole and is attatched to the bolt head. the washer is held between two pegs so as yo rotate the bolt it will move around in the slot. you need to get it properly 4 wheel aligned, back tyres should last 10 k +
665 bhp + 586 lbft...
Steviescottish
jimbo1234567
- 5th Gear
front subframe alignment affects the front wheel camber.
jimbo1234567
- 5th Gear
it can on the backgottanS wrote:Never heard of cross camber, the front wheel camber is adjusted to be equal both sides by re-aligning the subframe, i don't believe the camber can be increased or decreased individually each side.
Users browsing this forum: jdp and 82 guests
