Stereo will not shutdown removing ign key??
56 RS4
Normally you pull the key out and the radio turns off, all of a sudden it stays on and I have to press and hold the stereo button to make it power off!! Worried that it still may drain the battery this way.
Audi RNSE nav version - no idea of software version but think it has been updated by Audi in it's time!! Just out of warranty!!
Anyone seen this before or know anything I can try??
Ta
Ta
- northernpar
RE: Stereo will not shutdown removing ign key??
Never seen this before but know that the stereo on/off is controlled via the CAN-BUS. This means that power is on to the stereo all the time and is switched on and off by the engine/car management so there should be no worries about a flat battery once the stereo is switched off. Doesn't help with the fault but should give you some peace of mind about the battery.
I'm afraid I don't know enough about the Audi CAN-BUS to be of any real use on the actual fault but would suggest the first thing to try would be a reboot/reset of the RSN-E head unit. Can't remember exactly how it's done but I'm sure I read how to do it on a thread on here so might be worth a search (or another member will give a quick reminder). If that fails then I'm all out of guesses I'm afraid other than checking what revision software the RSN-E is running. If less that v0650 then worth an update to see if that cures. You can either buy a 2008 satnav DVD off fleabay for around £60 which will also update the maps to 2008 or you can do a search online and download v0650, burn it to DVD and then load it. I went for the £60 lazy option recently to cure some other bugs with the shuffle function.
good idea on the reboot will try that and another key! Thanks
I remembered this from last year. Is it relevant? It may stop you worrying.
http://www.rs246.com/index.php?name=PNp ... eaker+hiss
RS4 B7 Phantom Black
Angelo_Amato
- 1st Gear
Angelo_Amato
- 1st Gear
- PetrolDave
Users browsing this forum: No registered users and 219 guests
