Valves- carboning up
2manytoys
Post by 2manytoys » Sun Apr 04, 2010 10:14 pm
bfettie wrote:Ok Guys,time to pick your brains!!
I have noticed a considerable drop off in performance of late but not really had a chance to do much about it.To give you an idea I have tried a couple of Arthur's runs and average about 10 secs!! There is no 'vtec' at 5000rpm the epc light comes on sometimes more so when colder and it can have hesitations anywhere above 4000 rpm , still runs fine below that.All I have done so far is check the bungs I put in the vacuum pipes to the tailpipe valves which are still sound,so could it be the flaps and if so which ones ?
You should probably take the same route I took. Get the spark plugs changed first, or even look at the coil packs.
Audi can test the flaps in 10 minutes. Audi's program (like Vagcom) will monitor the flaps, and the procedure they go through will actually tell them what position they are in (as a percentage open). If they are faulty it will be picked up very quickly. Just a point, the sensor is so sensitive that it picked up a vacuum leak in my car, and I couldn't actually see the flaps moving (I could see the pressure in the gauge dropping, but only by a tiny bit).
bfettie
Post by bfettie » Mon Apr 05, 2010 4:20 pm
Thanks all , I was thinking it must be a vacuum leak somewhere as it suddenly started happening early in the new year just need to get it booked in when I get time . Car has now done 54k miles so probably all gunked up too but never done anything about it .............!
P_G
Post by P_G » Mon Apr 05, 2010 8:13 pm
I wouldn't worry about the mileage,I have passed 63k miles and with me and the kids (asleep!) on board today was still doing 8.4 second 3-8k rpm in third gear, 13 degree celcius outside temp, ESP on and damp road.
ArthurPE
Post by ArthurPE » Mon Apr 05, 2010 8:57 pm
P_G wrote:I wouldn't worry about the mileage,I have passed 63k miles and with me and the kids (asleep!) on board today was still doing 8.4 second 3-8k rpm in third gear, 13 degree celcius outside temp, ESP on and damp road.
that's going into the data base :D
how much fuel?
it's an avant too...
so a 63k car, never cleaned, with a load, in less than ideal conditions, meets factory spec (exeeds them if the wt diff for an avant and the load is factored in)
niiiiice
Post by HYFR » Mon Apr 05, 2010 9:24 pm
bfettie wrote:Thanks all , I was thinking it must be a vacuum leak somewhere as it suddenly started happening early in the new year just need to get it booked in when I get time . Car has now done 54k miles so probably all gunked up too but never done anything about it .............!
im on 73k, still fast as feck!!!!
i'll try and do the 3 - 8k rpm for you Arthur this week
ArthurPE
Post by ArthurPE » Mon Apr 05, 2010 10:19 pm
aka_dk wrote: im on 73k, still fast as feck!!!!
much appreciated!
but beware of guilt by association :lol:
send them by secret courier and deny all knowledge of my existence, lol
mark758
Post by mark758 » Mon Apr 05, 2010 11:47 pm
ArthurPE wrote:
...but beware of guilt by association :lol:
:D
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
ArthurPE
Post by ArthurPE » Tue Apr 06, 2010 12:32 am
mark758 wrote:
:D
lol
I'm a pariah, get too close to me and the stones intended for me may get you in the crossfire...I'm a 'deposits related performance' denyer!!!!!
:shock:
P_G
Post by P_G » Tue Apr 06, 2010 9:39 am
how much fuel?
niiiiice
2/3 of a tank left when I was doing that, 8.4 best, 8.6 worst
Brooner
Post by Brooner » Wed Apr 07, 2010 2:48 pm
Tried some runs today 5 deg 3/4 of a tank of fuel avant 8.2 to 8.4 sec 3-8k revs 23k miles on the clock
ArthurPE
Post by ArthurPE » Wed Apr 07, 2010 3:00 pm
Brooner wrote:Tried some runs today 5 deg 3/4 of a tank of fuel avant 8.2 to 8.4 sec 3-8k revs 23k miles on the clock
good times...very good for an avant, which is a bit heavier
oem ~8.4 to 8.5 for a sedan...
how many runs?
passenger?
valves ever cleaned?
going into the data base... :)
Brooner
Post by Brooner » Wed Apr 07, 2010 6:13 pm
4 runs even at 2 at 8.2 and 2 at 8.4 no passanger and never cleaned but have uses one dose of Wynnes DIP3 in tank and spray through air intake around the end of last year
ArthurPE
Post by ArthurPE » Wed Apr 07, 2010 6:51 pm
Brooner wrote:4 runs even at 2 at 8.2 and 2 at 8.4 no passanger and never cleaned but have uses one dose of Wynnes DIP3 in tank and spray through air intake around the end of last year
thanks you...imo, your car is running great
P_G
Post by P_G » Wed Apr 07, 2010 8:44 pm
When you sprayed it through the intake did you get a whole bunch of balck smoke out of the rear or changed the oil soon after?
Brooner
Post by Brooner » Thu Apr 08, 2010 8:11 am
Can't remember seeing any smoke or when the oil was change sry
Users browsing this forum: Bing [Bot] and 121 guests
