Lost Sound on radio
2.7 V6 30v biturbo - 380 bhp
RS4ever
Post by RS4ever » Sun Apr 04, 2010 5:27 pm
I eventually got this sorted. After changing aerial and the cable from radio to aerial it was still not fixed. Then someone looked inside the amp and contacts were corroded. Careful soldering fixed it. Radio now works
beejay
Post by beejay » Mon Apr 05, 2010 9:07 pm
Do you mean the AMP under the roof lining ? Ive booked the car into Audi next week to get it resolved. Once I find out what was broken I will update you all - Fingers crossed!!!!
R5YUG
Post by R5YUG » Tue Apr 06, 2010 11:19 am
I had a similar issue with poor Radio reception - the symptom sounds the same or similar.
I eventually traced it back to the diversity antenna (in the rear near-side compartment adjacent to the CD changer / DSP if you have one). One of the anntenas had a poor connection / dry joint. I ended up resoldering the connection and it's worked fine ever since.
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
pegbox7
Post by pegbox7 » Tue Apr 20, 2010 12:25 am
I had exactly the same problem and it is easy to fix and costs nothing !! The last poster is spot on, its just a dry joint on the small blackbox attached to the CD changer cradle in the passenger side cubby hole in your boot.
You can confirm this by wiggling the connector going in and as if by magic the radio will come on.
Solution re-solder the dry joint yourself or get a friend to do it..... :D
beejay
Post by beejay » Fri Apr 23, 2010 10:40 pm
If only mine was that simple. Had it in Audi last week and was quoted £554 inc vat to replace the aerial cable between the head unit and diversity antenna !!! Great value for money eh ! Thats on top of £190 of diagnosis !!
