Strange noise on boost above 4000rpm
2.7 V6 30v biturbo - 380 bhp
KiwiRS4
Post by KiwiRS4 » Mon Mar 29, 2010 9:29 am
Replaced the spark plugs over the weekend and noticed a new whistling sound above 4000rpm. It's definitely related to boost pressure but can't find out where the noise is coming from. Strapping a small child to the front of grill with the bonnet partially open to spot the noise is out of the question so it's onto RS246 for some advise.
I had to release two hoses off the y-pipe to get into the left bank. Thinking it was this I carefully checked everything ensuring no kinks but cannot pin point what it might be.
Any suggestions of where I should start looking?
Blue_Thunder
RE: Strange noise on boost above 4000rpm
Post by Blue_Thunder » Mon Mar 29, 2010 1:17 pm
A pressure test would find it.
Possibly a loose spark plug?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Mon Mar 29, 2010 9:08 pm
Is the metal tube fitted snugly where you removed the rubber pipe from?
On mine the metal tube was just sitting on top off the silicone joiner, where someone had tightened it properly. The 10mm bolt was holding it, otherwise it may have popped off!
Virdee Autos ~ 07950-526592
Users browsing this forum: No registered users and 132 guests
