help! my MPG is dump!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
fade2grey
Re: help! my MPG is dump!!
Post by fade2grey » Wed Dec 31, 2003 6:26 pm
my ave mpg drops a lot while the car is warming up, then creeps up (if I'm lucky) - short runs in this weather will kill your average mpg [img]images/graemlins/frown.gif[/img]
lpg anyone? [img]images/graemlins/smile.gif[/img]
A
98/Missano/Bose/Carbon
daddyjohal
Post by daddyjohal » Wed Dec 31, 2003 9:27 pm
i always thought warming the car up while staionary was 'bad' for it, isn't it? any idea why the mpg drops with this weather? isn't all that lovely cold air good for turbos?
chris22
Post by chris22 » Thu Jan 01, 2004 6:27 am
So did I [img]images/graemlins/confused.gif[/img]
Colder air means better performance (less heat)
Better performance means more fuel being used
I think.. Anyone think different.
Bass [img]images/graemlins/s3addict.gif[/img]
fade2grey
Post by fade2grey » Thu Jan 01, 2004 9:49 am
warming up while stationary isn't recommended.. something to do with oil pressure not being enough at tick over & the bores wearing.
Cold air is great for turbo's - more dense air & fuel means more power [img]images/graemlins/wink.gif[/img] but all of this is designed to work in a specific temp range so it's a case of drive easy until your water & oil temps are up, ideally trying not to hammer your turbo's too much (pretty hard on the S4 since they come in at about 5rpm!).
samtheman
Post by samtheman » Thu Jan 01, 2004 2:17 pm
oh sh1t, i start my car on cold mornings and leave it running for about half an hour to defrost it.. [img]images/graemlins/033102bad_1_prv.gif[/img] it cant do it to much damage can it??
daddyjohal
Post by daddyjohal » Thu Jan 01, 2004 3:02 pm
apparently so. oops!
samtheman
Post by samtheman » Thu Jan 01, 2004 3:30 pm
who told you that?
wazza
Post by wazza » Thu Jan 01, 2004 3:36 pm
and you wonder why you have bad mpg figures [img]images/graemlins/confused.gif[/img]
Paul
samtheman
Post by samtheman » Thu Jan 01, 2004 4:00 pm
he he fair enough, but i haven't done that for atleast 3-4 tanks of petrol..actually, when i did do that, the mpg figures were higher anyway!?? [img]images/graemlins/spineyes.gif[/img]
daddyjohal
Post by daddyjohal » Thu Jan 01, 2004 5:24 pm
who told you that?
READ YOUR OWNER'S MANUAL!!!!!!! [img]images/graemlins/wink.gif[/img]
samtheman
Post by samtheman » Thu Jan 01, 2004 5:56 pm
oh!! [img]images/graemlins/suicide.gif[/img]
DavidT
Post by DavidT » Thu Jan 01, 2004 6:31 pm
Manufacturers recommend warming the car up with gentle driving. This is because the warm up period causes most (70% ?) of engine wear so the longer the engine spends warming up, the more wear it suffers.
With the S4 i'd say no boost if possible until the oil is at least 90 C because the turbos are a weak element of the car and should therefore be warmed (and cooled down) gently.
Just my 2p
daddyjohal
Post by daddyjohal » Thu Jan 01, 2004 8:26 pm
off the top of my head, i don't think my oil temp ever reads 90c!
ajsl
Post by ajsl » Fri Jan 02, 2004 3:19 am
I take it pretty easy until the oil temp is a least over 60deg. I don't really see the temp over 90 very often though! Perhaps I'm too easy on it [img]images/graemlins/wink.gif[/img]
fade2grey
Post by fade2grey » Fri Jan 02, 2004 10:20 am
Yup, I'd agree with that, though once the water reaches 90 the oil gauage is alredy at about 60-70 degrees on mine. As long as the oil guage is moving I start to give it more gass. Mind, it's hard not using the turbo's - I was amazed when I first got the car, driving down the road with the window down, you could hear them spool from about 13-1400 rpm! cool! [img]images/graemlins/smile.gif[/img] My alfa 155 Q4 does NOTHING until about 2800 & then wham it gives you the lot! - it also pulls full boost to the redline which I miss but hey, the S4 is more comfy! [img]images/graemlins/smile.gif[/img]
A
