http://www.ross-tech.com/vag-com/cars/throttlebody.html
Sorry, not the most technical of guys on here, but from what i can work out mine is a DBW Car using KWP-2089
is this correct? thanks
TBA @ VAGCOM: which one is correct for B6 S4?
RE: TBA @ VAGCOM: which one is correct for B6 S4?
Yes Lee, the B6 S4 is drive by wire. My 04 plate is the KWP-2089. I would suspect your's will be too, but your Ross-tech software will tell you this when it does the initial handshake (top left hand corner).
04 Audi S4 B6 Moro Blue Saloon
Peugeot 205 MI16 with twin 45's for the track (in the Garage)
Honda Prelude 2.2Vti - Gone but not forgotton
TR7 - well rid of
Triumph Spitfire - student wheels
TR7 - well rid of
- PetrolDave
For a B6 S4 you need at least a dual K-line cable. There are no CAN diagnostics on the B6, that was added on the B7 - which has dual K-line and CAN diagnostics. And the B8 has CAN diagnostics only.
Ok, I think this has been touched upon before but i can't find it. I have just bought a genuine Ross-Tech hex can bus and done the throttle body alignment and the reading is throttle drive angle sensor 1 14.7 and sensor 2 85.1 should one of these be 100 or is it the combined total that should be 100 (ie 14.7 + 85.1) in which case mine is fine.
2005 B6 S4 cabriolet.
Now to sort out the brake problem that I purchased it for.........gulp........
Users browsing this forum: No registered users and 27 guests
